12" CVRs AMP help...
Username: Spankinurwoofers
GR, MI US
Post Number: 109
Hey, I just bought two older kicker compvr's. they're 400 wrms, and dual 4 ohm voice coil.
What would be a decent-quality (looking cheaper than $150) amp that does 400x2 RMS @ 2 ohms or 800x1 RMS @ 1 ohm??? Or can they take more power, and sound better? Thanks.
Username: Nickyp0219
Post Number: 319
with that budget, less than 150, id be looking at hifonics or somethin, jmo
Username: Jakeyplaysbass
ASU
Post Number: 2342
http://sonicelectronix.com/item_9551_Hifonics+TXi1008D.html
Thats about as close as youll get for something new. Search ebay for used stuff...it might be a little closer to 150.
Username: Nd4spd18
Northwest PA
Post Number: 5408
^^^^^ way overrated
hifonics 1206d is probably the cheapest decent amp for those..... ya need a little more money
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1477
uprage to 230 and get the rockford fosgate t5001bd,im pushing my cvrs'sw ith that amp,its birthsheet is 969 watts
GR, MI US
Post Number: 110
they're the older cvr's that arent rated for as much power, would that amp overpower them? (or just set gains right?)
Amp i have right now, from my old setup is the crunch pzi325.2(rated, 300 x 2 rms @ 2 ohms) overrated, but would that power them ok???
Username: Somedonniedude
Illinois United States
Post Number: 726
x2 on the rf t5001bd. This is a good place to buy from to.
ebayhttp://cgi.ebay.com/ROCKFORD-FOSGATE-POWER-T5001BD-Monoblock-Amplifier-Amp_W0QQi temZ300188420887QQihZ020QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Cblaze
Post Number: 1479
long as u leave the bass boost alone and set the gain right,them subs should be fine
GR, MI US
Post Number: 111
sweet thanks...anything else that would work, just for comparison, so i have a little selection to choose from??? Thanks again guys.
GR, MI US
Post Number: 112
Also, for the box, would ~1 cu.ft. be enough for each sub? Still have a box if it'll work. (building a cheap-ish system for a friend, lol)
Username: Cblaze
Post Number: 1480
i thank there minum is like 1.5 cubes
GR, MI US
Post Number: 113
well, i'm going to remeasure the box, i thought it was only ~2cu.ft....not sure tho. also, it's a sealed box, not ported. Better off just making a bigger ported box???
Username: Cblaze
Post Number: 1481
yeah i would give them 2 cubic ft each in a ported box,they will be alot louder
Username: Kyle_lowe
Post Number: 764
audiobahn a8000t does its rated 800@1ohm
and about 130 on ebay new
GR, MI US
Post Number: 114
HA...sorry, i just realized, i just bought 2 of those exact amps(A8000T's)!.
Though they were going to be for my setup, i guess i could spare a used one that i have for my friend and get a new one off ebay for myself...
GR, MI US
Post Number: 115
wait...just occurred to me, isnt the A8000T only 2 ohm stable??? i thought it was 800@2ohm not @1ohm^
Username: Naledge503
Http://www.LowDownForu...
Post Number: 2697
Yes, the A8000T and A8000V do their power at 2 ohm and the A8002T and A8002V do their power at 4ohm.
GR, MI US
Post Number: 116
ok, how could i hook up the A8000T to two cvr's that are dual 4 ohm?
GR, MI US
Post Number: 117
Also, any input on the overheating of these amps? Somebody told me they overheat a lot.
GR, MI US
Post Number: 119
bump, two dual 4 ohm subs to a 2 ohm stable amp...possible???
Post Number: 729
You could only run that amp at 4 ohms with those subs. So no you wont get full power to them with that amp.
GR, MI US
Post Number: 121
Thats what I thought, but had to make sure. Thanks.
