Digital television
Username: Jayson
Post Number: 67
Does anybody knows what will happen with FTA after february 2009 with the digital TV conversion?
Thanks a lot.
Username: Mucho
Post Number: 27
There is only one person here that could
answer your question.He predicts the future.
Ask for King Tapeman.
Username: Kirankumar
Kenya
Post Number: 848
fta should be around for a long time, remember fta signal is digital anyway ,you may have to change your TV if it is analog
Username: Jayson
Post Number: 70
thanks for your answers.......but what I don't understand is if all the receivers will be able to get all the channels......because right now we need HD receivers with modules to get HD channels......will the actual receivers will be able to get every channel or will we need new receivers??
Thanks in advance.
Kenya
Post Number: 852
Jayson,
tv standards are changing to digital not hd so there is no issue , because you will still get channels in digital
Username: Tapeman
New York City in-HD, NY
Post Number: 2099
There are three Broadcasts today:
1- Analog
2- Digital
3- HD
This will affect local broadcast via conventional Antenna's
Keep in mind conventional antenna's receive both analog and digital
Only Analog that will be phase out in 2/2009
Analog represents less than 15% of today's television broadcast anyway
Log on this site
Enter your Zip Code and see what will be affected
http://www.antennaweb.org/aw/Address.aspx
If yo have an old TV set by 2009
It will be time to start shopping or purchase an adapter
Username: Saqeeb9000
Post Number: 1512
i think its only for U>S ...not in canada
Username: Tapeman
Post Number: 2102
Yo are right
I never thought it
Username: Jayson
Post Number: 71
thanks guys......I appreciate that........
Username: Joed
PLATINUM VIP MEMBER
Post Number: 65
Only in USA but if you use an over the air antenna to pickup local USA TV stations you won't be able to pick them up without a digital TV or tuner.
