Clifford Concept 500 - Central Locking & Turbo Timer - help required please.
Username: Cswminty
Tamworth, Staffs UK
Post Number: 12
HI,
I have wired in my Concept 500 and it all seems ok and the laptop agrees.
My only problem is that i can only get the drivers door to lock and unlock with the alarm.
it's a Subaru impreza that needed a solenoid adding to lock the drivers door as it did only work with a key and then lock all the others from this.
I have the grey and orange & grey and green to the solenoid and the red's to 12v and the white's to earth.
Am i missing something here please ???
Also does anyoen know how to wire up a turbo timer to the alarm, i saw on my last car when the clifford engineer fitted it, it turned out to be just a relay and some fancy wiring. Does anyone know how to do this please??
Also can you wire the intelli start to start without priming it in a manual gearbox, i also saw this done on my last car.
I would greatly appreciate any help.
Thanks
Chris.
