2 12" Sub suggestions?
Username: Vash3000
Post Number: 98
I'm planning to get a pair of 12" subs and need some suggestions. So far I've narrowed it down to FI Q, Alpine Type R/X, FI SSD, MTX 9500, or any other subs that you guys think can top these within the price range of $500. I also need the subs to be good in a small about 1.o cubic feet sealed. Im planning to give it around 1600watts for both subs. Im looking for sql, something that will get loud but yet sound good.
Username: Rovin
4 10 Pioneer...
Post Number: 12768
i only have experience with the type R sealed & in fact i used 1cuft for it when i had mine so i can guaranty u it surprise u how good & loud it sounds .....
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J... USA
Post Number: 1005
yes my friend has two 12" R's on about 1200 watts thing gets loud as hell!! hes running it on stock electrical so when he turns it up high his stuff shuts off. not smart but he wont listen
Username: Surferdude9371
Admiting your an a$$ho...
Post Number: 452
rs are really popular and qs have great sq depends what u want
Username: Mendonmafia
Post Number: 594
ive heard that q's get extremely loud for the amount of sq they have. ive also been looking for a pair of 12's for a while now and alot of ppl hear are guiding me towards the RE SX supposedly gets really loud yet still has some SQ. but from experience i had kappa perfect 12's that really slammed and would work well in a 1 cubic foot sealed box but idk if the pair could handle 1600 rms.
Username: Alpine97
Paramount, California USA
Post Number: 153
The pair of RE SE's????
Username: Alpine97
Post Number: 154
The RE SX will take about 1,000 to 1,500 RMS........and will get very very loud. Just get on youtube and watch some flex videos..
Username: Ska
Post Number: 11
get some treo ssi's, you'll be very happy
Username: Vash3000
Post Number: 99
Yea i was looking into some RE SX, but like I said, I only have enough space for a 1.0 cubic feet sealed space for each sub. So total is around 1.6 cubic feet. The SX needs a ported box and I doubt I have the space for even 1 12" SX. I'm surprised that no one told me to go with the 12" fi Q sealed? You all dont like Q's or sumthing? As for the Treo SSI's, how big of a box do those need? I know the Type R's are good budget subs and hit hard.
Username: Audiosaab
Potomac, MD
Post Number: 101
im using 2 alpine type R's with a Hifonics Brutus Bxi 1606D mono amp....belive me they are a good choice. Each one is rated as a max of 500rms and yet im currently hitting them around 700rms and they have not yet burned out, ripped, or have had any strain on them but pump at full capacity as expected. I dont have much experience with type X alpines but i hear they are also pretty good..so either one id go with personally if i had to do it again. :-)
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13574
Q's
nothing else on the list can compare
Username: •cam•
BC Canada
Post Number: 1641
I was thinking about a pair of BTL 12s with the extended coils and 3rd magnet. Tune it low. I think I could squeeze in the 15s, though. Hmm.
Username: Bonhamd
Northern, Michigan USA
Post Number: 80
I have a couple of Diamond Audio D9s if interested
Username: Jnoel
AIM= j69noel, KY
Post Number: 897
i used to run two treo ssi 15's and wasnt dissapointed..i ran them on 2k for the pair... 1600w should make some treo ssi 12's sound real good
