New fixes - Pansat and Viewsat
Username: Nydas
Post Number: 7115
All new Viewsat files are avaialble at:
[link removed]
http://www.thetotalfta.com
__________________
__________________
Platinum
DBPSW-080114P Freezing Fix
fixes issue with freezing
DBPSW-080114P.zip (944.1 KB)
__________________
PVR
PVRSW_080114A Freezing Fix
PVRSW_080114A.zip (2.25 MB)
__________________
HD 9000
PFTAHDSW-080114 Freezing Fix
fixes issue with freezing.
PFTAHDSW-080114H.zip (3.41 MB)
__________________
PRO
VSPRO-080114A Freezing Fix
VSPRO-080114A.zip (1.53 MB)
__________________
Ultra
PFTAUSW-080114U Freezing Fix
PFTAUSW-080114U.zip (1.10 MB)
__________________
Extreme
DBPSW-080114X Freezing Fix
DBPSW-080114X.zip (937.6 KB)
__________________
Username: Nydas
Post Number: 7116
All new Pansat files are available at:
[link removed]
Working bins as of 9:30 PM PST Jan 13th 6000 and 5000 do not need to be updated.
9200HD dIsH/B3v uP
9000HD dIsH/B3v uP
6000HXC dIsH/B3v uP
5000 dIsH/b3v uP
250SM dIsH/B3v uP
3500SD dIsH/B3v uP
2800A dIsH/B3v uP
2700A dIsH/B3v uP
Username: Nydas
Post Number: 7117
For Pansat 2500 or FLU to 2700 conversions.
This file for converted receivers only and is NOT suitable for genuine Pansat 2700 or for clone Pansat 2700.
Use only on Converted receivers.
CS_236T_Lightning_100t_Series_serial.bin
CS_236T_FS-LifeTime-Ultra - Flash 1(29LV800BTC) - JTAG.bin
These are available as zipped files at:
[link removed]
in th eFortec and Pansat 2500 sections of files.
Also available as
CS_236t_serial_and jtag.zip at:
http://public.box.net/2500_full_kit
Username: Locnoir
Post Number: 49
Thanks, Nalin!
Username: Dandaniels
Post Number: 13
Nalin, Hope you can help. I have the piece of crap Fortec lifetime classic NA. As I said it is a piece of crap. One reliable but s*hit now.
Do you know of a bin and where I can find it. The place where I use to get the info is all but shut down.
Also tell me what YOU think is the best FTA reciever on the market now. With the best support and all.
Thanks
Dannyboy
Username: Leafs
Post Number: 358
visit www.ftasolutions.blogspot. com for latest files and keys...
Username: Cricket674
Post Number: 175
Nalin...
I have a question.. I have a converted Pansat 2700 (2500/2700) and I am using the CS 232 bin and it is working fine. My question is Am I risking my receiver and should I put the new converted bin???
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 531
other sites are reporting the 236 is not working on Fortecs either...stay where u are until it clears up if this bin is working or not...too many conflicting threads and I will not test it because I am satisfied with even and odds for now...all its claimed to do is fix freezing...mi box with the CS_231 bin freezes once every 4 or 5 hours for 30 seconds only
Post Number: 533
v236 release for Fortec Non Operational
Non Operational files for fortec v236
CS_236T_Lightning_100t_Series_serial.zip
Note: Do not Load
"posted on other sites"
Username: Skeptik
Artica
Post Number: 25
These are available as zipped files at NOT WORKING:
[link removed]
Also NOT WORKING:available as
Username: Realdio
Monterrey, Nuevo Leon Mexico
Post Number: 32
Skeptik i loaded the CS_236T_Lightning_100t_Series_serial on my converted pansat 2700 and does not work.
Username: Realdio
Post Number: 35
Do I need to load this file also ? CS_236T_FS-LifeTime-Ultra - Flash 1(29LV800BTC) - JTAG
Username: Luv2meet
Post Number: 13
Guys, when you will learn to read before posting questions? Skeptik post was clear,the 236T is no good. Though, there is another version 236Tv2 that just got release but it has a bug .. it skips half of the channels when scanning.. my suggestion ... stay with the old bins for now.
Post Number: 544
unless you use channel master and add your channels..all porns gone with new bin but PPV movies are up
Username: Realdio
Post Number: 36
I have channel master, please post 236Tv2
