Can anyone design me a box ill paypal a lil cash
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J... USA
Post Number: 1027
I need a slot ported box design for the 2 10" MA audio 101x I can't post the specs at this moment but they can be found at Maaudio.com ... I tryed to use subwoofer tools but I'm 2 retarted 2 understand what I'm looking at I want a 3d design that shows me all sides and inside veiws so I can make this box myself its my first one so thts why I dnt know what I'm doin
Post Number: 1028
250W Rms
500W Max
Single/Dual 4-Ohm Voice Coils
50 Oz. Single Magnet
Mounting Depth: 5.6"
Mounting Diameter: 9.2"
Optimum Vented Box: 175 Cu/Ft
Round Port Diameter: 4" x 9"
Square Port Area: 2.5" x 8" x 11.5"
Optimum Sealed Box: 1 Cu/Ft
Tuning @ 40Hz
Username: Jtown
Team Revolution, Texas
Post Number: 1643
IonSQL, BJs box designer charges $10-$25, he changed prices a lil while back, but I don't know if he dropped them back down. He gives you the cut sheet and multiple angles and views of the box, inside and out, as well as all correct measurements
Post Number: 1032
yea but im trying to start making this today he will probably take a couple days to get back to me. I know someone thats good at this is on the forum today with a lil free time. thanks bro
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5066
i would design you one for free...but it wouldnt be 3-d
Post Number: 1034
well would it be easy enough for a noob 2 read bcuz i dnt have the slightest idea how to construct a box from the diagram tht subwoofer tools gives you
Post Number: 1038
bump
Post Number: 5068
because subwoofer tools suck.
do you have AIM?
Post Number: 1039
yea its CEO of da ROC4
Post Number: 5072
2.5 cubic ft
40hz
44 sq inches of port
Post Number: 1040
thanks sooo much driving i really appreciate it im bout 2 start working now and put my woodlawn apprenticeship to work! thankx again dude
Post Number: 5075
no problem bud.
Username: Andrew571
Post Number: 1383
1000+ posts and cant design basic box???
Let alone use subwoofer tools?
Post Number: 1042
i never designed boxes before. evry1 is a critic go DRIZZLE your foolishness somewhere else
Username: Andrew571
Post Number: 1384
Its cool dude, I just thought maybe u might have learned how to make a cube and do math to find volume by now.
Sorry i had expectations for you.
Post Number: 1044
Well drizzle ill impress u later when I post a nearly finished box. I mean BJ doesn't design his own boxes mean while his are a lot more complicated than this but still... well I'm learning how to do it as we speak. Drving is helpin me alot
