VS Xtreme BIN
Username: Beenthere
Post Number: 33
2 Questions: 1st what BIN should I use to avoid the freeze, and what site is the best downloading to put all the the Channels on my reciever? Channelmaster.com? or what?
Username: Luser
Post Number: 20
All bins are freezing. Maybe a new one will come out today. Dates are written into the file name. VS does'nt need channel files because when you do a channel scan it grabs all the info from the sat on the first transponder it reads with a signal.
Username: Beenthere
Post Number: 34
Semore, which way is the best way to do a scan, I only have 113 ch's
Username: Beenthere
Post Number: 35
If I do a scan will I loose what I have? sorry new to this.
Username: Luser
Post Number: 21
Most important is scan each sat/lnb seperatly bypassing any switches.They always screw it up.Freq 11250 Watch your Q signal while doing your ant. setup and be sure the sat name that appears upon good signal matches the one your setting up.
Username: Mdl97
Post Number: 86
bin from 12-26 is working great.i installed couple days ago and it only freezes once every couple of hours.
Username: Madflea168
Post Number: 29
if you don't delete the sat and do a scan on the same sat, you will end up with double the same channels.
both 071226 and 071222 should work.
Username: Hi09
Post Number: 62
which site archives the BINS i.e. where can i get both 071226 and 071222 should work.
Username: Kirankumar
Kenya
Post Number: 926
in your mothers azz and if you don't find it there try your sisters azz
Username: Nydas
Post Number: 7119
New fixes out for Viewsats
https://www.ecoustics.com/electronics/forum/home-video/434405.html
