New member Username: Bn1Post Number: 6 Registered: Jan-08 | I don't know the answer.. :/ What type of speakers go in the rear.. Coaxial or Mids or are they the same or does it matter? |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 12359 Registered: Jun-06 | Depends on their size. 4-6.5" coaxials usually on the doors. 6X9 coaxials rear deck. Coaxial just means the speaker is a combination of a tweeter and a mid bass or woofer. Your midrange will come from your coaxials. Leave the lows to your subs, in the rear or trunk. I wouldn't put mids in the rear. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5357 Registered: Jul-06 | NO speakers in the rear is ideal. http://www.glasswolf.net/caraudio/rearfill.html |
