ZAC DAVIS
Username: Surferdude9371
Admiting your an a$$ho...
Post Number: 455
in another thread you said you set the gain to match the head unit. my kx2500.1 goes from one to 11 is that volts do you know? thnx man
Username: Zacdavis
Beloit, Wi
Post Number: 1515
one to 11?
Do you mean 11 to .1?
Post Number: 456
leme find a pic just one sec
Post Number: 457
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D200191123830&indexURL=0&p hotoDisplayType=2#ebayphotohosting
Username: Drant19
DUB-C, TX
Post Number: 193
lmao it says "Gain" right next to it...
Username: Drant19
DUB-C, TX
Post Number: 194
thats not the volts. its probably on the side of the amp
Post Number: 458
i know where the gain is that wasnt my question....
Username: Zacdavis
Beloit, Wi
Post Number: 1516
If you refer to the owners manual it says actual value.
I have a manual (spanish though) for the KX 4, 6, and 1200.1's and it says...
170mV - 5 V
and
340mV - 10V
Post Number: 459
ok ill look up the mannual thnx so much bud
Username: Zacdavis
Beloit, Wi
Post Number: 1517
BTW, those are high levels and low levels.
The lower value is when using RCA inputs the other is when using speaker level inputs.
Post Number: 460
im so lost lol i looked at manual and couldnt fig it out if i want it at 2v which number should i have it on?
