Username: Volfenhagking1600 SSD Wangin,
Shawano, Wis...
Post Number: 1147 Registered: Oct-06
Sunday, January 13, 2008 - 17:26 GMT My friends windows on his explorer dont go down...checked all the fuses and all good. Any idea what it could be..? Thanks Jamie
Username: M0nkeyman692 Post Number: 484 Registered: Feb-07
Sunday, January 13, 2008 - 19:20 GMT explorers do that all the time. sry i dont know how to fix it, but i know its a cheap fix at the auto shop. also if it hasnt already happened hes gona have to get a new ignition cause they always jam up and then the key wont turn. there are a few things that explorers are notorious for.
Username: Extrmndor3 Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7422 Registered: Feb-06
Sunday, January 13, 2008 - 20:33 GMT u gotta buy a new window motor.... well 200k miles on my explorer and i never had that thing happened to my pretty truck ;)
Username: Surferdude9371 Admiting your an a$$ho...
Post Number: 449 Registered: Mar-07
Sunday, January 13, 2008 - 20:34 GMT temp open up the door panel and bang on the motor and it MIGHT work for a lil bit but u do need to replace it
Username: Fred_sanford Huntsville,
Alabama
Usa
Post Number: 98 Registered: Nov-07
Sunday, January 13, 2008 - 21:45 GMT i work in a parts store and i can tell you those window motors go bad alot but also the master window switch on the drivers door go bad alot to.
