Cs4000 160 problems
Username: Kb56
Hey,
I loaded up my cs4000 with the 160 bin and reprogrammed the channels on satellites 110, 119, and 148.
Every 15 minutes or so, Scramble Channel. With autoroll off and not looking for new keys, it fixes itself after about 30 seconds. Another 15 minutes later it goes out again and comes back. Does anyone know a solution to this problem? ...other than waiting out that 30 seconds
Thanks,
KB
Username: Kirankumar
Kenya
Post Number: 862
KB,
everybody has the same problem ,just wait for new fix when it comes out , in the meantime enjoy what you have while you have it
Username: Nydas
Post Number: 7078
For some PANSATs and C00LSATs
As of now DN is working fully well using BINs dated around 22-26 Dec 2007.
BEV has put a different type of ECM causing the older BINs mentioned above to work properly on even channels and the latest BIN to work on odd channels
Similar situation might apply to CaptiveWorks and Viewsats
