2 12's
Username: Pbplayer05
Carroll, Iowa
Post Number: 227
what would a good pair of twlves be i just bought an md2d so about 1800 wrms is what ill have for the two
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5050
2 Fi SSDs
2 RE SEs
2 Treo TSX
2 TREO TEs
2 DD 2512s
2 WMDs
2 SI BMs
2 T3 TSS
ect..
Carroll, Iowa
Post Number: 228
well i have two bms now but is that gunna be to much for them
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1411
justin the the md2d is rated at 1500rms and now that i thank about it u might not have to really worry about keepin the gain down.it only has 3x40 fuses,what kinda car u got.
Username: Alpine97
Paramount, California USA
Post Number: 84
Two RE SE's for the money would satisfy you..Just get on Youtube and see how 2 RE SE 12's will flex your ride..
Post Number: 5054
i think itll be fine for the BMs
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 576
i got two 12" RE SE and i love them! www.youtube.com/kingandsons07
Carroll, Iowa
Post Number: 229
well its a 95 monte carlo ls it has 105 amp alt
i read somewhere that it is suppose to do 1800
Username: Cblaze
Post Number: 1429
that amp will run fine on a 105 amp alt,leave the bass boost off,prolly already know that,and just dont blast it at idle and u shhouldnt have a prob.i got a 105 amp alt.and am runnign a amp that pulls the same amount of power from the alt.it has never dropped below 13 volts,usually drops to about 13.6 volts when the bass hits
Carroll, Iowa
Post Number: 230
good i hope it dont hurt it i was gunna just wait till i get a bigger alt but if it wont hurt it to bad ill prolly turn it up then
Carroll, Iowa
Post Number: 231
also what about a single sub setup for this amp wat would work good
Username: Cblaze
Post Number: 1431
sure wont long as u keep that voltage above 12 volts.that amp wont drop it that low anyways
Username: Cblaze
Post Number: 1432
re sx 15 ported,u can get them on ebay for about 300 shipped,that sub will bang hard with the md2d..take alook at it
http://cgi.ebay.com/RE-AUDIO-SX15-15-SX-SUB-WOOFER-RESONANT-ENGINEERING-07_W0QQi temZ150204185087QQihZ005QQcategoryZ18804QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 577
i would get a ext batt an HC1800 and do the big 3 if not done yet and do all 1/0 and you should be set
Username: Cblaze
Post Number: 1433
battery wont help anythang,thats just a waiste of money for him.big 3 would help tho.im running a amp that pulls the same amount of power with a regular battery and no big 3 and everythang is fine...
Post Number: 579
what are you looking for sq,sql,spl? maybe a 3515 or a BL?
Post Number: 580
at idle i get 15v and with music i get 13.9v when drivin with muisc 14.3v and thats with the xt-2000d putting out 43.4v to my Q i wish i had a md2d or a saz-1500
Username: Nd4spd18
Northwest PA
Post Number: 5347
1500w is pushing it on that alternator
Carroll, Iowa
Post Number: 232
well i was told by someone on this forum that doing the big three with stock alt wont help any
Username: Cblaze
Post Number: 1438
big 3 does help.lets more current threw.a extra battery wont help.batterys store power.they dont make it. m.s. its not really about the watts its about amperes.im pulling the same amount of amperes from a alt of the same size,and no probs
Carroll, Iowa
Post Number: 234
so i should be ok then
Username: •cam•
BC Canada
Post Number: 1626
Chris, I wouldn't try to school M.S.
Username: Cblaze
Post Number: 1445
i aint trying to school em.not being being a smart azz but he dont know everythang thang,like ppl thank.no offence m.s.
Username: •cam•
BC Canada
Post Number: 1628
Well, you can bet he knows his electricity basics.
Username: Cblaze
Post Number: 1448
ok
Carroll, Iowa
Post Number: 236
so will i be ok or not i will be doint the big three soon
Carroll, Iowa
Post Number: 237
so would any of the ones listed be better than my 2 bms i was also thinking of maybe getting 2 of the new audioques would they be better or worse than what i have
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J... USA
Post Number: 997
yea i have a saz 1500d tht does about 1700 to 1800 and the told me i need a HO alt. but for my car there so expensive the cheapest 1 i find was 400 for a 180A.
