Im trying to learn...
Username: Ford_bronco
Ok I want to buy these speakers. http://www.sonicelectronix.com/item_8815_MTX+Audio+XT693.html
and buy this amp and subs. http://www.sonicelectronix.com/item_9444_Visonik+VB210PKW.html
I just got lost by the RMS and Peak Power. I dont have a deck yet but I will probably be buying a alpine, I dont want to buy those speakers and blow them or there not good enough,
thanks in advance!
Will I have to buy an AMP for the speakers aswell? I dont need really any bass out of them, I just wanted to no if there gunna be decent.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1151
Whoa.. First why don't you tell us how much money you have to spend and what kind of budget you are working with.
6x9's and Visonik both suck.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1152
I meant what kind of budget do you have and what kind of sound you want. Like SQ/ SQL or SPL.
Blonde moment.
I want the best sound for the money, What is SQ/ SQL or SPL ? I no nothing about speakers/ decks or anything electronic.
Why do 6x9's suck? Have you owned Visonik?
thanks.
Username: Nd4spd18
Northwest PA
Post Number: 5411
no offense but to put it bluntly,
mtx = not good
visonik = crap
Round speakers = better than non-round
Post what your max budget is and what all you need amp, subs, speakers, etc. and we can decide the best for the money.........
I dont really have a "max" budget. I think im just going to wait till I finsh rebuilding the truck then look into stereo's.
