Lost signal on CS5000
Username: Silver1123
Mexico, DF Mexico
Post Number: 440
Is there a new ECM or key change?
Just lost all channels en Charlie en my CS5000
Username: Kirankumar
Kenya
Post Number: 842
juan,
you should load bin 160 ,if you still have problems then post here and we will help. good luck
Mexico, DF Mexico
Post Number: 441
I have 160 and it was working great on DN.
A while ago, all got scrambled.
I disconnected my CS and connected my nFusion,which is working great.
Kenya
Post Number: 845
did you wait for a while to see if it came back up,try a hard reboot also , it should work
Username: Taikimoto
Post Number: 29
also have the 5000 it shows scrambled signal
when the channel freezes will kick back in
in less then a minute
Kenya
Post Number: 847
That's correct , but I guess we all are panicking too much because of all the ecms
when scrambled channel comes up just wait , don't change channels
