(4) 18" subs in escalade
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 688
i got about 700$ to spend and im thinking this is what im gonna do
1. (4) 18" mach 5 audio MJ subs all single 4 ohm
2. power it with (2) 2200 power acoustik 2 channel amps
note: might get the 2600
3. kicker 4 gauge wire kit
4. custom sealed box with subs facing up
this will be going into a 2002 escalade and i have the 3rd row seat took out and my last set-up was a kicker 1200.1 with a 15 inch L7 but do u think if i go with this setup it would out pump (2) 15 inch L7 subs? i know these are SQ subs but they should get very loud knowing im getting 4 of them
Username: Yukhui
4 15 AA Havocs, Memphis 4kw!!
Post Number: 831
If you want 4 18's and to get em loud, save up some more.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2008
It would be loud and sound good. There is probably better, but that's not bad by any means as far as the subs go. I would not recommend the PA amps tho. Also, you won't be able to run a 4-gauge kit with that much power. You'll need to go with 1/0 gauge.
Listen to Colby and save up some more money.
Username: Jnoel
AIM= j69noel, KY
Post Number: 878
ma audio sux but you got a start....
Username: •cam•
BC Canada
Post Number: 1630
This is not MA, this is Mach 5.
Username: Nickyp0219
Post Number: 307
still have that kx1200? if so how much would you sell it for
Post Number: 689
sorry dont have the kx no more...i wish i did though!!!
im getting the kicker 1/0 wire kit by the way not the 4 and i dunno about all of you but the speakers really seem to be good for the money which 1 only cost 116 shipped
Username: Naledge503
Http://www.LowDownForu...
Post Number: 2667
Hey you're the guy asking about the amp over on CA right? That amp would work awesome with those subs. Are those amps you listed the ov2-2200d? Cause if it is, they are really only rated at 900rms at 4 ohm.
Username: Tejcurrent
Post Number: 985
^ I agree with colby and would save up a bit more. You'll really want to upgrade your electrical (h/o alt, good battery/extra battery) first too.
Username: Turnmat
Racine, Wi
Post Number: 582
x2 Save up some more money and if you wanted to stay with Mach 5 get the IXL-18.4. <--that would be sweet
Username: Rovin
4 10 Pioneer...
Post Number: 12753
y would any1 want 4 18s ...unless u going for spl
i would do just 2 18s Fi BTL instead ....
Username: Turnmat
Racine, Wi
Post Number: 583
you know for those ocasions that one two or even three subs just isnt enough to feed your need for bass
Post Number: 309
but wont that take up the entire back half of the escalade? you really wanna sacrifice that much room?
Post Number: 986
A decent box for 2 18s still takes up most of the back of an escalade, so if you can fanangle a good box why not do 4?
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J... USA
Post Number: 998
yea sounds like hes going to need alot more than 700 dollars sheez my setup cost like 2 Grand and its only 2 12" and a single amp with HO alt etc etc so i know tht 4 18" will cost alot more than tht.
Username: Basssquared
Kansas
Post Number: 1867
Dwight kinda seems like you got ripped off. you gotta know where to buy. i bought 2 15" RE SXs 07's and an 07 MD 2D built my own box using my stock stereo and my total came out to 550 dollars so yeah and i can guarantee you my system will be louder than your 2 12" DD's.
Username: Jkidder
Gunshine , State Flawda
Post Number: 3036
lol ray puttin down other ppl's system when he finally got a lil one.....
haha
Kansas
Post Number: 1869
no i'm not putting down his system i'm putting down the fact that he paid 2 grand for a system that in my opinion is no where near worth 2 grand.
Username: Jkidder
Post Number: 3037
oh but if he got good quality equipment i dont see how he got ripped off.
Kansas
Post Number: 1870
if you say so Jonathan ;)
Username: Th3pwn3r
Post Number:...
Post Number: 6494
"Dwight kinda seems like you got ripped off. you gotta know where to buy. i bought 2 15" RE SXs 07's and an 07 MD 2D built my own box using my stock stereo and my total came out to 550 dollars so yeah and i can guarantee you my system will be louder than your 2 12" DD's."
Dude, why are you hating man? You still have a stock head unit, c'mon. Step up your game before you talk sh1t Ray!
Kansas
Post Number: 1872
i'm not hating and i have a stock head unit by choice i dont wanna loose the stock look and the steering wheel controls i actually own a really nice Panasonic HU.
Post Number: 1010
PG rsd6.5 comp set -87 bucks shipped
speaker adapters - 20 shipped
PG amp - 125 shipped
Sundown Audio 1500d _450 shipped
2 12" dd 2512 -450 shipped
woodlawn box built to specs _240 i think i got it made in 1 day
180aMP ho ALT - 400
KICKER 0 guage wire kit 90 shipPED
Alpine Head Unit the one tht only plays ipods and mp3 player - 265 shipped
Should i continue with deadener etc etc????
o ok i didnt think so a system is alot more than an amp and subs ray u forget about all the lil things like wiring and sound deadening didnt u. ok now do ur math and let me know what u come up with. o ok thought so...
Kansas
Post Number: 1875
speakers STOCK
HU STOCK
Speaker amp STOCK
2 15" RE SX 250 Shipped
MD 2D 250 Shipped
4 ga Wiring 50
built my own box 30
Grand total 580 dollars so yeah
people may talk sh!t on Bose but my car came with a stock Bose premium sound system and the mids and highs are nice i like them and find no need to replace them.
