Final box help
Username: Santa_fe
02 Hyundia Santa Fe, 120.3 db not...
Post Number: 455
ok these are my plans......http://www.subwoofertools.com/forum/ported-box.asp?Ew=35&Eh=20&Dia=9&Xmax=21&Vd= 0.17&NumW=1&Vb=3.5&Fb=35&Qts=&Vas=&Fs=&CE=0
iv got all the wood cut and now im wonderwing if i should have the violet piece ion there??? would it make more of a difference??? juts curious and could i shorten it mabey to me it looks to long in the box........
Username: •cam•
BC Canada
Post Number: 1631
Yes, removing the violet piece will change the tuning drastically.
Username: Santa_fe
Post Number: 456
well what about shortening it??
Username: Van_man
Boston South, MA
Post Number: 3264
Shortening it will make the tuning go up (Boom Box). I would add to it and make the tuning 32
Username: Tatonka
-[Team Audib...
Post Number: 1316
Shortening it will also mess up tuning. Any modifications to the port length or size will take your tuning out of wack.
Username: Santa_fe
Post Number: 457
so if i shorten it it would be at what any ideas???cuz the design now is 35 hz but everyone else i have talked to tunes higer ya know....so would it be okay?
Username: Santa_fe
Post Number: 458
bump
Username: Santa_fe
Post Number: 459
ok so i re measured all the measurements and my 15 will not fit inside the box plans........wtf??? help guys im drowning in confusion....espcially since i already made the cuts and the made all the cuts right soo wtf is worng here????
Username: Santa_fe
Post Number: 460
heeeeeeeeeeellpppp
Username: Santa_fe
Post Number: 461
help..
Username: Santa_fe
Post Number: 463
bump!!!!
Username: Rovin
4 10 Pioneer...
Post Number: 12756
y doesnt it fit ? .....
Username: Santa_fe
Post Number: 464
well i have to cut a 14in hole to mount the sub on it and the violet piece is to long but i cut it to the design exactly...now i have triple checked all the cuts im going insane....keep postin rovin lol
Username: Rovin
4 10 Pioneer...
Post Number: 12758
so the back of the sub is touching the port then ? ...
Username: Santa_fe
Post Number: 465
yesssss u understand thankgod!!! yea violet piece to to long.....if i shorten it 3 in exactly it fits fine....the sub should go where the port stops right in the yellow and red cornorish right???
Username: Rovin
4 10 Pioneer...
Post Number: 12760
well u can shorten it but tuning will go up but i guess u cant help it since u already cut the wood
so just retype a higher tuning on the calculator to see what u get since u may need to retrim a few pieces of wood .....i done it b4 ....
Username: Santa_fe
Post Number: 466
ill only need to trim that one violet piece right? and 3in isent that bad
Username: Santa_fe
Post Number: 467
im so pissed im just trim that violet piece down 3 in and say fug it.....it will still sound decent right?
A pic is worth 1000 posts!!
Post Number: 12356
How much does the back of the sub hit the port? Maybe add another baffle or two on the front to pull the sub away from the port?
How about inverting the sub? Do you have room for that?
Username: Rovin
4 10 Pioneer...
Post Number: 12761
no dude its not as simple as trimming off a measly 3" ...when u do that it also alters the cuft & tuning of the entire box which may aslo affects its shape
but in this case ur lucky since u only need to trim & widen the port a bit
http://www.subwoofertools.com/forum/ported-box.asp?Ew=35&Eh=20&Dia=9&Xmax=21&Vd= 0.17&NumW=1&Vb=3.5&Fb=37.5&Qts=&Vas=&Fs=&CE=0
note now the port is 4" wide ...up from 3.75" ...new tuning 37.5hz to give u that needed clearance .....
Username: Santa_fe
Post Number: 468
okay fixed all the dimensions...thanx a bunch rovin...ill shoot a vid after its all done....but why would subwoofer tools show me a box that had wrong dimenions???
Username: Santa_fe
Post Number: 470
okay i think im okay acutally if i mount the sub on the red side wall it fits fine is this how i was suposed to do it originally?? or is this a bad idea???? plzz post guys link to the box is at top!!
Post Number: 12360
Yeah I would've assumed the sub to be mounted on the red side anyway.
