Good box dsign???
Username: Santa_fe
02 Hyundia Santa Fe, 120.3 db not...
Post Number: 448
why does this box look like it wont be that condusive any suggestions....its drawn to the suggested specs on the FI website
Username: Santa_fe
Post Number: 449
http://www.subwoofertools.com/forum/ported-box.asp?Ew=17&Eh=20&Dia=9&Xmax=21&Vd= 0.17&NumW=1&Vb=3&Fb=35&Qts=&Vas=&Fs=&CE=0
Username: Vc23
Fi , 2 12 Fi Bls U.s.a
Post Number: 254
well you got 20 inches and 17 inches... you gotta make it wider for 3 cubes... otherwise the depth is gonna be sticking out of your trunk... switch it to like 25 or 26 then the depth will go down... then you should be good... unless you dont have that kinda room...
Username: Santa_fe
Post Number: 450
well i want it like 20 inches high and like 17 inches wide and it can be up to 40 inches long....so its okay then??
Username: Santa_fe
Post Number: 451
bump
Username: Santa_fe
Post Number: 452
plzzz help me here guys building it today!!!!!!
Username: Rovin
4 10 Pioneer...
Post Number: 12748
er so y do u want it only 17 wide x 20 tall (unless ur fitting 2 subs & building 2 boxes ?)
try entering a longer width instead & try different values to get a more uniformed looking box ......
Username: Santa_fe
Post Number: 453
http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=20&Dia=9&Xmax=21&Vd= 0.17&NumW=1&Vb=3.5&Fb=35&Qts=&Vas=&Fs=&CE=0
is this better?? i guess im a lil confised on the width and deep part....is deep also length??? and is width being shown as lenght on the plans??
Username: Rovin
4 10 Pioneer...
Post Number: 12749
what u should do is lengthen it even more so taht its now 1 long port instead of multiple ports so u get a better more efficient airflow
like this :
http://www.subwoofertools.com/forum/ported-box.asp?Ew=35&Eh=20&Dia=9&Xmax=21&Vd= 0.17&NumW=1&Vb=3.5&Fb=35&Qts=&Vas=&Fs=&CE=0
Username: Santa_fe
Post Number: 454
hey rovin thanx alot man...now is 35 hz to low for a fi SSD 15????
