Poppin noise?
Username: Cplaya280
Pennsylvania USA
Post Number: 856
my friend has a HDC315 running off a zx1000.1 and sometimes on certain songs the sub would like make a poppin sound. r at least it sounds like it? whats up with that?
Username: Jnoel
AIM= j69noel, KY
Post Number: 876
is it tensel slap
Username: Cplaya280
Pennsylvania USA
Post Number: 857
lol we dont kno, like sumtimes certain songs, u would hear sumin like a odd poppin sound....
Username: Cplaya280
Pennsylvania USA
Post Number: 858
bump.
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 5807
What box?
Is the amp clipping?
Is the sub moving alot?
Username: Cplaya280
Pennsylvania USA
Post Number: 859
its in a 3.5 tuned @ 37hz made by woodlawn, im not sure about if the amp is clipping but the gain is set a lil bit past the middle wit no BB and on the headunit its a premier 780 subwoofer setting at +5.
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 1112
You wont get tinsel slap with an audioque. they weave it into the spyder.
Username: Sinful_systems70
15 INCH WANG...
Post Number: 1134
It could be dirty files, I bet all the songs that do it are on a burned CD or were downloaded!!!!
Username: Jakeyplaysbass
ASU
Post Number: 2330
"It could be dirty files, I bet all the songs that do it are on a burned CD or were downloaded!!!!"
Good call...
How did you set the gain? By ear or DMM?
Also your RCAs might be touching something at the HU but i seriously doubt its that.
15 INCH WANG...
Post Number: 1138
If, so ground your RCA's at the head unit like this.....
Username: Nd4spd18
Northwest PA
Post Number: 5362
^^^^ haha the ghetto fix for crappy pioneers
Username: Vash3000
Post Number: 94
I had a problem like that with my subs before as well. I had 2 JL 10W7 in a sealed and when I turned it up, it would make popping noise and its not even that loud. I found out that it was my amp not pushing enough watts to the subs. I changed the amp and it still did similar problem, and then I found out that my chargin system wasnt up to it. After I fix that, the subs now play loud and good. So check your amp to see if its pushing enough watts to the subs and if your charging system is good.
15 INCH WANG...
Post Number: 1166
Thats not a poineer!!!!!!
15 INCH WANG...
Post Number: 1167
"crappy pioneers" maybe but Pioneer Premier is most definetly NOT crappy!!!!!
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 253
I'm running the Deh880 and it is certainly not CRAP.
Username: Th3pwn3r
Post Number:...
Post Number: 6495
Premiers have problems with grounding issues all the time as well.I wouldn't buy one for that reason.
Username: Nd4spd18
Northwest PA
Post Number: 5409
^^^ yep
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13543
Both of my vehicles have Pioneer HU's...If you install them correctly no noise will be heard..User Error FTL!!
15 INCH WANG...
Post Number: 1170
x2
