Gold Member Username: NydasPost Number: 6986 Registered: Jun-06 | Having read reports of end of Dec., 2007 Viewsat Sonicview working, I loaded in a 2500 to 2700 converted receiver the CS_232T_lightning BIN and the Indian Channels on Echo 3 are working. I think the 2700 genuine Pansat with BL87_232 BIN the clone Pansat 2700 with 232v1 Tivo and the converted (2500/flu to 2700) with CS_232T_Lightning or equivalent jvvh_232 BIN should all work. I have yet to scan Echo 8.1 for PPV and th eclone |
Silver Member Username: BvvenegasPost Number: 162 Registered: Apr-07 | so if i have a genuine pansat 2700a and i load bin cs 232T it should work again |
Gold Member Username: NydasPost Number: 6993 Registered: Jun-06 | NO - for genuine pansats use BL87 BINs and 27.02 loader. I just said it in my post. |
Silver Member Username: BvvenegasPost Number: 163 Registered: Apr-07 | where is your post so i can look at it |
Silver Member Username: LeafsPost Number: 335 Registered: Oct-07 | those files have been posted at |
Bronze Member Username: KrishnPost Number: 47 Registered: Sep-06 | Genuine Pansat BL87_233 works |
Silver Member Username: Snw7619Bahamas Post Number: 145 Registered: Oct-06 | how do i know if my 2500>2700 clone is a FLU? |
Silver Member Username: P0tzzzUSA Post Number: 101 Registered: Dec-07 | confirmed...Bin 232 is working on Pansat 2700a |
Bronze Member Username: Hades305Post Number: 25 Registered: Aug-07 | works on converted 2500-2700 clone |
Silver Member Username: BvvenegasPost Number: 164 Registered: Apr-07 | i went to the ftasolutions.blogspot and found the download for pansat 2700a original it downloads bin 233 and says that those are fixes reported working can someone help me please |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 23 Registered: Jun-06 | does the pansat 2700 bin wrk for pansat 3000? |
Gold Member Username: NydasPost Number: 7000 Registered: Jun-06 | For Pansat 2500/FLU new conversions and converted to 2700 Use only on converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones The latest ECM of 10th January, requires that you use the 232 or 233 BINs. These have been posted separately in Conversion_232_233.zip file. http://public.box.net/2500_full_kit FOR FIX dated 10th January, 2008. |
Bronze Member Username: Woohoo331Toronto, Ontario Canada Post Number: 23 Registered: Dec-07 | 232 works on clone 2700 |
Bronze Member Username: Sparky41701Chavies, Ky Usa Post Number: 82 Registered: Jun-06 | so do we need to change the boot file from bl 75 to bl87 |
Bronze Member Username: Polo69Post Number: 20 Registered: Dec-06 | NALIN is it 235 or 232 bin in that link?? |
Gold Member Username: NydasPost Number: 7015 Registered: Jun-06 | There is everything - the full kit with 234/235 BINs several versions. Separate file for 232/233 BINs. Why don't you click on the link and find out what is there? |
Bronze Member Username: Polo69Post Number: 21 Registered: Dec-06 | yes i do but i see 235t |
Bronze Member Username: IqqiesPost Number: 47 Registered: Jul-07 | dish is totally working!!!!!! |
Bronze Member Username: LeafarPost Number: 30 Registered: Jun-06 | yea pansat realy work whit bin 232 nice |
Silver Member Username: ImnycusaPost Number: 101 Registered: Jun-06 | Yaar Nalin, I dont see files there. |
Gold Member Username: NydasPost Number: 7031 Registered: Jun-06 | http://public.box.net/2500_full_kit There are four files there Conversion_232-233.zip is the one for the older BINs which you need now. There are four 232-233 BINs inside the zipped file. I just checked and downloaded from there. |
Silver Member Username: ImnycusaPost Number: 102 Registered: Jun-06 | i m sure i must be doing something different thats why i dont see the files there. when i click the link, all i see is "box" heading, but no files. i wonder if anybody else is experiencing the same thing? |
Silver Member Username: ImnycusaPost Number: 104 Registered: Jun-06 | i closed the browser and reopened it. it worked. |
