Silver Member Username: 2pacalypse1971Sandusky, Oh Post Number: 464 Registered: Jul-05 | ok i have a prefab box for 2 12 that is ported, i bought this a while back, and i'm thinkin of ordering two 12's, no nidea which ones, but i don't really want it ported no more, say i got a piece of wood and screwed it over the port, would that be considered a 'sealed' box then??, because i jsut wnat a normal sealed box |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1385 Registered: Sep-07 | not really lol its still gonna leak air out unless u seal it up with wood glue or somethang |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5307 Registered: Jul-06 | Just get a real box |
Silver Member Username: Nickyp0219Post Number: 293 Registered: Jun-06 | why dont you want ported any longer? |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1390 Registered: Sep-07 | ported will kill any sealed box.ported is for spl,u said that was what ya wanted |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 1096 Registered: Mar-07 | Just build your own box. |
Silver Member Username: 2pacalypse1971Sandusky, Oh Post Number: 465 Registered: Jul-05 | cuz them prefab ported boxes sounds like Sh!t in my opinon, i guess i'll have to have box built whenever i do end up gettin some new subs, building aruond the subs that is |
Gold Member Username: CblazeRock island, Tenesssee Us Post Number: 1392 Registered: Sep-07 | use this site to design the box http://www.subwoofertools.com/forum/ported-box.asp |
Bronze Member Username: MdcustomsGrand Rapids, MI USA Post Number: 25 Registered: Jun-06 | You could do that but I would not recommend it. Ported enclosures are going to be bigger then sealed enclsores. So if you seal the port you are going to have a real large sealed enclosure. That could sound even worse. www.MDCustomz.com |
