Help out a noob
Username: Deadrabit
Post Number: 121
i have an 18 blt but i am wanting some bad a$s speakers.
i don't realy know much about door speakers. is more better? i know of a friend that had some under his seats and they sounded better than stock ones.
i know ur going to want to know how much i can spend. i was thinking like 500 bucks or so. but i will spend more if it really makes that big of a difference.
with sql or spl on door speakers will spl have more bass? or will it just be loader in general?
i want something that sounds amazing like the band is right in front of me.
i am not sure how my 18 will sound in a car so might get sell it and get 2 12 btls.
give me some ideas/
i have the time and i can do some custom work if more speakers are better.
Username: Deadrabit
Post Number: 122
so i just read some stuff and my freind did not have speakers in the rear and i am thinking that is y they sound so good?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1165
Well, it sounds like you want some like some good sounding speakers.
With $500 you could get an array of equipment.
Do you have an amp for the fronts, and if so what kind of power does it do/what is it? What kind of amp for the 18? Stock alternator?
Username: Deadrabit
Post Number: 123
i have a stock alternator but i am getting a new one. right now i have a 10001 rockford power but ill prolly sell it and get an md3d 2k amp.
i don't have an amp for the door speakers but i figured i would want to get one. i just don't know what is good and wats not.
from what i am reading i need to move my rear speakers to under the front seats or some place different. is this right?
Username: Waresgaragestereo
Fort Valley, GA United States
Its just my opinion, I don't have a problem w/ rear speakers. i have mine in the rear deck and they sound good. 1990 Cadi. DeVille. for the dual amps, get a HO alt. and another battery. From what I've heard, Capicitors are NO GOOD. Caps don't work like they should. A HO alt. is your best bet.
HO = High Output
Username: Nd4spd18
Northwest PA
Post Number: 5452
X2 on the HO alternator is a must have if you're getting an MD-3D
Post Number: 8
M.S. What about the rear speakers? For my information, should you or should you not have them? or does it matter?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1168
No rear speakers, actually worsens sound wquality. Spend more money on better fronts or pocket the money.
Username: Nd4spd18
Northwest PA
Post Number: 5456
http://www.glasswolf.net/caraudio/rearfill.html
Username: Deadrabit
Post Number: 125
ok.. so i know no rear speakers. and i am getting a new alternator... but what kind of door speakers should i get? what kind of amp for the door speakers?
Username: Drant19
DUB-C, TX
Post Number: 183
for the front stage look at a 2channel amp or a 4channel and bridge it. thats what i have. just get an amp that will easily power the speakers (i.e. if rms on speakers is 70-90, then get an amp that does 100 just so it doesnt have to work hard to push them.)
Username: Nd4spd18
Northwest PA
Post Number: 5457
^^^^ exactly. and if you want something that "sounds amazing like the band is right in front of me" your going to have to spend more than $500 for speakers and amp.
My recommendation:
CDT HD components
Alpine MRP-F550
why? Because thats my setup.... :-)
Username: Drant19
DUB-C, TX
Post Number: 190
^ballin azz set up fo sho!
i wish i had those...
M.S. do you think those HD's are better than my infinity ref comps? lol
Username: Nd4spd18
Northwest PA
Post Number: 5465
Holy sh!t yeah........ even alpine's mid level speakers are better than infinity.
Username: Deadrabit
Post Number: 126
i went to the car audio place and listen to some stuff and listened to a few speaker and found some that really i liked... then i ask him how much it was and gosh.. it was 900 bucks..
SO!!!! for 300 bucks just the speakers give me some stuff that i should look at. ill see if i can listen to those
Username: Nd4spd18
Northwest PA
Post Number: 5499
You can get the HDs for around $350
Contact alteraudiousa
Username: Nd4spd18
Northwest PA
Post Number: 5500
Focal, rainbow, and crystal also make some nice speakers, not sure on prices though
Username: Deadrabit
Post Number: 127
the focal ones that i liked were the ones that cost a lot. other than them there was some pioneer premier that sounded good but they were 459. and i know there is better than pioneer.
does polk make good stuff?
Username: Nd4spd18
Northwest PA
Post Number: 5502
Their speakers are ok but they don't hold a candle to CDT, focal, rainbow, etc.
Since you liked those high end focals: Focal makes a set that sells for ~$250-300, maybe give those a listen. I have heard them and would take the HDs over them though.
Username: Deadrabit
Post Number: 128
i didn't like the cheaper focal as much. but u gave me the anwser i wanted. thanks
if i need anything else ill post again
