Bronze Member Username: 4azeefPost Number: 17 Registered: Aug-07 | My receiver kept saying sercing signal. it was working fine until yesterday. i did hard reboot 3 times still same thing. would it have anything to do with high wind? anyone having same problem in ON, Canada? |
New member Username: PressmanjrPost Number: 1 Registered: Jan-08 | am having the same problem, and am located in ON. Checked all the connections and all are in tact. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3276 Registered: Sep-06 | https://www.ecoustics.com/electronics/forum/home-video/431069.html |
Gold Member Username: NydasPost Number: 6964 Registered: Jun-06 | Did you install the latest Viewsat Ultra BIN? PFTAUSW-080108U-1.zip It is dated yesterday and available at [link removed] |
New member Username: PressmanjrPost Number: 2 Registered: Jan-08 | Thanks for the info. Followed the steps in FTA TESTER's link and loaded the latest Ultra bin...still no luck. Bare with me as I'm new at this, but I have S in the 60's but no Q. As of yesterday both were in the 80's and 70's. Does S mean I have a signal? Any advice would help. |
Silver Member Username: Bill038Post Number: 419 Registered: Sep-06 | S means your viewsat is talking to your lnb's. 0 Q means you are not getting any signal from the sat to your lnb. Maybe your set up or maybe your connections, maybe your dish has moved. |
