Dish installation question???
Username: Juchito97
i'm a newbie, i live in florida i know i need a dish 500, now, how many LNB and what type of LNB i need? also what satellite i need to pick up, the 119 or the 110 or both, i need help.
Username: Rtap
FL
Post Number: 1578
luis give more info to help you.what sat box.you can get a dish pro lnb which allows you to get both 110 and 119 with no need of adding any disque switch, will allow you to connect more than one receiver.when you get the antenna go to this site to angle your antenna easily.http://satcalculator.freehostia.com/
Username: Juchito97
i have a cw800, but do i have to had both 119 and 110 or one is enough? please explain what LNB i need if i need to pick one sat or what LNB i need if i need to pick up two sat.
Username: Rtap
FL
Post Number: 1579
luis the more sats you add the more channel. with 110 and 119 you can get around 400-600 channels on dishnet.the picture on my post is good enough to get you both 110/119.give me you email and i can give info on a store near you to pick up what ever u need.
Username: Juchito97
sorry but im so new with this, i see in that picture that all together there 4 output,i have one receiver, you mention i dont need a diseqc, so how i do the cable installation, where do i connect those 4 cable?
Username: Rtap
FL
Post Number: 1581
luis the four output on the lnb allows you to connect up to four receivers.each output goes to a different receiver.when you have single lnb you must run a disque switch to control them.this dual lnb comes with a switch inside already.
Username: Juchito97
ok so of the 4 output i only going to use one straight to the receiver correct? also the diseqc is for multi satellite or multi receiver?
Username: Rtap
FL
Post Number: 1584
good luck.anymore help let me know.
Username: Juchito97
Username: Rtap
FL
Post Number: 1585
correct luis straight to the receiver.the disque switch is used for both.
Username: Juchito97
a dual LNB is one LNB with two output or just two LNBs?
Username: Rtap
FL
Post Number: 1588
a dual lnb is as the picture i posted.you can get 2 sats with it.its to lnb together
Username: Free_tver
a dish pro dual lnb is two lnb with two outs.
Username: Free_tver
Post Number: 7
a dishpro quad lnb is two lnb with 4 outputs
Username: Rtap
FL
Post Number: 1590
correct free tver.
Username: Juchito97
Post Number: 9
right now i got two LNBs, (not dual) each have two output so that mean i can use it but i need a diseqc correct? that way one is going to pick up 119 and the other one 110 correct?
Username: Free_tver
Post Number: 8
correct
Username: Rtap
FL
Post Number: 1592
remember luis to run the cables to the switch from the same side of lnbs. left side from both lnb to switch or right side from both lnb to switch.
Username: Rtap
FL
Post Number: 1594
Username: Juchito97
Post Number: 11
so i connect the first LNB to sat 1 on the diseqc and the second LNB to sat 2 and leave sat 3 and sat 4 empty , this sound correct?
Username: Rtap
FL
Post Number: 1599
remember that sat 119 goes in #1 and 110 goes on #2.
looking behind the dish 110 is on the right and 119 is on the left.
Username: Juchito97
Post Number: 12
to make sure, looking from behind the LNBs 110 is on my left and 119 is on right?
Username: Rtap
FL
Post Number: 1600
no luis 110 is on your right and 119 is on your left.looking behind the dish
Username: Juchito97
Post Number: 16
i got confused, ok i got a DP twin LNB, one output in each side(two output all together) i run one single cable from one of those output straight to the receiver with out any switch and thats good enough to pick up both 119 and 110??? or i need any switch? also whats the different between a diseqc,sw21 and 22khz switch?
Username: One_eye_jack
Post Number: 185
Luis, you and RTAP are correct.
He is looking from behind the Dish.
You were looking from behind the LNB's
He was looking toward South.
You was looking toward North.
