Missing CNN & Freezing issues with VS PVR 7K with 080103A bin.
Username: Bonguemikaadu
I am using VS PVR 7K and using bin dated 080103A.
I am having freezing of channels very frequently. Channels freezes for every 10 to 15 mins for 1-2 mins.
Did any of you having this issue ?
Also, I am missing CNN channel.
Can someone give me SAT, TPs for CNN.
Thanks in advance.
Username: Rtap
FL
Post Number: 1625
load an older bin.i beleive its on date 12/22
RTAP, Thanks for the reply.
So by loading 12/22 bin, would it set the freezing issue ?
And any help on my other question ? missing CNN channel ?
Username: Rtap
FL
Post Number: 1626
it should if it doesn't just turn autoroll of see if this helps.if you need the file go to crazyfta.com
Username: Madflea168
Post Number: 31
both 081226 and 071222 should work on the vs, they both freeze on me, but seems 071222 a bit less than 071226.
by turning auto roll off never work for me, end up always show no a/v signals.
