Username: Buddho81 Post Number: 66 Registered: May-06
Tuesday, January 08, 2008 - 17:59 GMT There is a new bin that came out today fix the freeze and autoroll stuff---not sure if anyone has seen it. I just received the new file so if anyone is interested let me know where i can upload it! Thanks, CHEERS!
Username: Coolcanada Post Number: 31 Registered: Aug-06
Tuesday, January 08, 2008 - 18:14 GMT where did u find the files
Username: Kirankumar Kenya
Post Number: 789 Registered: Oct-07
Tuesday, January 08, 2008 - 18:16 GMT Cool, it's at f2atv
Username: Smoke74 Post Number: 109 Registered: Oct-07
Tuesday, January 08, 2008 - 18:33 GMT also at ftaforall.net
Username: Coolcanada Post Number: 32 Registered: Aug-06
Tuesday, January 08, 2008 - 18:35 GMT thanx got it.
Username: Rtap FL
Post Number: 1608 Registered: Jan-07
Tuesday, January 08, 2008 - 18:44 GMT also available at PFTAUSW-080108U-1 fixes the channel delay issue. Use at your own risk. PFTAUSW-080108U-1.zip __________________ read the rules/lea las reglas: http://ftabins.net/announcement.php?f=3
Username: Rohinivikas Post Number: 39 Registered: Dec-07
Tuesday, January 08, 2008 - 19:15 GMT Did somebody use this BIN? When ever i change the channels, i see Autoroll processing for 10-15 seconds before the channel comes. Would this bin fix this issue? Has it been tested?
Username: Nydas Post Number: 6927 Registered: Jun-06
Tuesday, January 08, 2008 - 20:16 GMT The following new releases are available at: [link removed] and many other sites. Viewsat Ultra PFTAUSW-080108U-1 Channel Delay Fix Viewsat 2000/Platinum/lite DBPSW-080108P-1 Channel Delay Fix Viewsat Extreme DBPSW-080108X-1 Channel Delay Fix Viewsat 9000 HD PFTAHDSW-080108H Channel Delay Fix
Username: Asplover Post Number: 79 Registered: Jun-06
Tuesday, January 08, 2008 - 20:16 GMT You have to do a manual reboot to your box and it will be ok afterwards.
Username: Leafs Post Number: 324 Registered: Oct-07
Tuesday, January 08, 2008 - 20:27 GMT new viewsat files posted at www.ftasolutions.blogspot .com (remove space)
Username: Rohinivikas Post Number: 40 Registered: Dec-07
Tuesday, January 08, 2008 - 20:49 GMT How do i do a manual reboot? You mean switch off from the rear.
Username: Nydas Post Number: 6930 Registered: Jun-06
Wednesday, January 09, 2008 - 01:59 GMT Vikas Nanda : YES
Username: Jayson Post Number: 54 Registered: Aug-06
Wednesday, January 09, 2008 - 02:14 GMT file tested and working!!!!!
Username: Dafidof Post Number: 28 Registered: Dec-07
Wednesday, January 09, 2008 - 03:12 GMT The vs ultra one works for DN only, it doesn't work for BEV
Username: Cartier1 Post Number: 1651 Registered: Feb-07
Wednesday, January 09, 2008 - 05:41 GMT yes it does
Username: Viewsat_ultra Post Number: 40 Registered: Nov-07
Wednesday, January 09, 2008 - 08:06 GMT I see that this bin is at total,did any1 get it from there?
Username: Jayson Post Number: 57 Registered: Aug-06
Wednesday, January 09, 2008 - 12:28 GMT it's your receiver.......you can blow it up if you want by getting files from the total sites.........
Username: Dafidof Post Number: 30 Registered: Dec-07
Wednesday, January 09, 2008 - 13:28 GMT So where can I get the files? do you have a trusted name website?
Username: Bernardmi Post Number: 40 Registered: Dec-07
Wednesday, January 09, 2008 - 13:39 GMT I have tested the Platinum. Works extremely well indeed as long as you don't change satellites. If you go elsewhere and back, you do have to wait the 30 or so seconds. But if you browse channels on a same satellite, it is really quick
Username: Dafidof Post Number: 31 Registered: Dec-07
Wednesday, January 09, 2008 - 14:18 GMT "The Outer Limits" from wich site you download the bin?
Username: Jayson Post Number: 59 Registered: Aug-06
Wednesday, January 09, 2008 - 17:35 GMT use ftaforall.net.......
