Problem getting all BEV Channels
Username: Eelz
Post Number: 11
Hi folks,
I have a Viewsat Ultra pointed at BEV. When I do a scan I do not get all the channels missing quite a few (especially the 600s). When I tried scanning a second time I basically got duplicates of the same channels in my Channel list (Which is very annoying).
Any ideas how I can get rid of all the duplicate channels and get a complete list of channels. I have a subbed receiver that picks up all the channels but would like to get the Ultra getting them all.
Setup - a BEV (0901) installed dish with 1 LNB with two feeds going into a Eagle Aspen S-2140-CE Mini Max 3x4 Multiswitch 40-2050Mhz. One feed goes into the 18v Sat input and second feed goes into 13v Sat input (installed by BEV installer). Three receivers are fed by this switch (one of which is the Ultra in question). Have tried scanning with the Ultra on three of the outputs with the same results.
Any help to get rid of the duplicates in my list and to get a full list of BEV channels?
Thanks
Username: Eelz
Post Number: 12
BTW here is how my Antena Setup is:
LNB Power - ON
LNB Type - OCS-DP
LNB Freq. - 11250
22KHz - Off
TP Freq. - 12224
DiSEqC 1.0 - None
Motor - Off
Legacy SW - None
These were the default settings and I did not make any changes.
Any help is appreciated.
Username: Tanhoura
Post Number: 14
hello where can i find BIN for FORTEC LIFETIME CLASSIC NA please advise thanks
Username: Tanhoura
Post Number: 15
Username: Eelz
Post Number: 13
Don't HiJack people's threads please.
Username: Dafidof
Post Number: 34
eels, change the LNB Type (try standard or universal or any other but not OCS-DP)
Username: Ke5aqn
Post Number: 3277
eels you more than likly have a crupt satfile here is a guide on how to fix that
https://www.ecoustics.com/electronics/forum/home-video/431069.html
Username: Tapeman
New York City in-HD, NY
Post Number: 2051
Nope
That is the arrivals of second stream
Marks the arrivals of Nagra-3
Try to avoid blind scan for now
Just regular chan scan
Not much yo can do
Username: Hangon
Post Number: 11
I am having a problem with dish alignment. I am able to get 91 and not 82, or 82 and not 91 at the same time. I have the Dish 500 Legacy twin LNB with 4x1 DISEqC. I am able to get 110 and 119 with no problems and 91 and 82 with an old DirectTv single LNB. I have an extra Dish 500 mounted and I want to hit the Birds 91 and 82. I am in Idaho USA. Pansat 2500A convert to 2700 bin CS235t. Any help please.
Username: Tapeman
Post Number: 2053
"I am able to get 91 and not 82, or 82 and not 91 at the same time"
That's cuz yo need 1 LNB for each sat
Twin LNB means 2 LNBs for two Sats
Single LNB for 1 Sat not 82/91
"91 and 82 with an old DirectTv single LNB"
I don't think so
What yo would need
- 1 Dish twin LNB for 110/119
- A second dish with 2 LNBs for 82/91
- 1 DISEqC switch to combine all 4 sats
- Set each Sat one at a time in antenna settings
- Always turn off receiver as yo add any coaxial input to DISEqC switch
Username: Hangon
Post Number: 12
I have a second Dish twin LNB's I can not line up the Dish to hit both 91 and 82 at the same time. What am I doing wrong or do I have the wrong Dish?
Username: Jgrumby
Post Number: 14
The dish will work just fine. Your dish skew might need adjusted to receive both sats at the same time.
