Tore my sh!t up
Username: Livin_loud
Do Work Fi Audio
Post Number: 2131
well i've always wanted to do it, and tonite i did. took out the backseat of the ride, and now have my 18" sittin b!tch haha. BUT, all is not well...
i ended up loosing a good chunk of dB from the usual sweet spot of 30-40hz. however i gained a good amount below 30hz and a whole lot at 50hz+, which was just not there before.
sub is facing up, port firing into the back of the passenger seat. i haven't sealed off my trunk yet though. will this yield results if i do??
il get pics up tomorrow...
IM THE REAL SLIM SHADY
Post Number: 16639
it will make a world of difference when you seal up the trunk. you'd be amazed.
Do Work Fi Audio
Post Number: 2133
ooo that sounds like a good deal to me haha... what did you do chad? i have the metal plate i removed and i figure i'll just deaden it, carpet over and just put it back...
i also don't know if i'm going to keep the setup if it doesn't give me a good enough difference, because no back seat limits many a things. but i do have a trunk now :-)
Post Number: 16640
taht is what i did. i just covered the whole rear deck with the deadener. i put put duct tape over the rear deck first before i put the deadener.
Username: Safe_cracker
Chicago, IL US
Post Number: 3871
Join the peanut gallery, lOl. Milwaukee sawzall is my best friend! Now with a lot of experimenting this has proven to be optimal for my vehicle, effectively removing the trunk area from the cabin and eliminating most of the back wave from box flex. I call it my Trunk Delete and I still have room for some groceries or such. Polo..
http://s237.photobucket.com/albums/ff98/Master_Safe_Cracker/?start=60
Post Number: 16652
very nice polo. looks insane man. lol. you are crazy though. your car will never be normal again. lol.
Chicago, IL US
Post Number: 3872
Hey Chad this was done last summer DORK! Was just showing someone who hasn't seen it. I still have to cut the old box out and insert the new Fisher box...Polo.
Do Work Fi Audio
Post Number: 2139
i like the setup Polo, however i don't think i'll ever go that far haha.
well this is how things currently stand. its a huge mess lol. basically just moved the box to the back seat which i didn't bother taking out...
unfortunately im thinking this box isn't going to work if i want to keep it like this soo... i figure i have 2 options from this point.
1. i can keep the back seat off, put my box back in the trunk and see what happens, trying it port in and then port back
2. if i'm not satisfied i'll have to build a new box because this one doesn't quite fit. in the last pic it shows the box coming in past the point that seals the trunk off.
i'm definitely not happy where it stands so option 1 will be put into action tomorrow...
