Cw 7OO or cw 8OO, or something else????
Username: Auk786
Can u tell me how fast the bin comes out for these boxes, how easy it is to install the bins, and how reliable these boxes are and any thing else. Plz a quick reply wud be appreciated
Username: Rtap
FL
Post Number: 1587
lately with the ecm changes bins are taking longer than expected for every box.my advice to you is go with a viewsat,sonicview.
Username: Auk786
any viewsat or sonic view in particular??
Username: Rtap
FL
Post Number: 1589
go with any that have the option to update with usb port.
Username: Juchito97
Post Number: 7
hey im a newbie but i can tell you that any cw is very easy to set up and bins are never late.
Username: Auk786
THANKS for ur help guys i decided to get the cw 700 cuz it has the usb port and it seems very simple to use
Username: Rtap
FL
Post Number: 1595
good luck.
Username: Brucester
Post Number: 961
it is a great box it is all most like cw600p but you can load by usb stick and cw has great support and is geting better and better with every bin this time round cw was up 3 or 4 days before the big boys and the rest of the time 3 to 6 houres after the big boys and i think cw will stay on top of the game for a while had my cw600p for 2 years now i think it is the best box for your doller
Username: Brucester
Post Number: 962
How-to: CW-700S USB or Cable Setup Guide
USB Instructions
Download and Unzip latest bin file.
Transfer unzipped file onto USB stick then plug it into the box. You should see a message that says USB ready. Now press the USB button on remote and then scroll to the right to open the Software tab. Look for new file and press OK to load it. After it loads, it will ask you if you want to reboot, say YES.
When it reboots then go in menu and do a Factory Default. Then reboot again from the rear power switch. When it comes back up again, now you can setup satellites and options and rescan all satellites. After that is done, exit out of all menus and with the remote press F1 000 to enable the Patch. You should see a message on your tv that will say PATCH ENABLED. Now wait for keys to roll and watch tv.
Cable Instructions
To Prepare Receiver:
Turn off and attach the null-modem cable between the receiver and the computer serial port.Then plug in the power plug.
With the CaptiveWorks 700 receiver off, press the front power button and hold it.
While holding it, turn the rear toggle switch on, while STILL holding front power button.
You will see "boot" on the front display.
1. Download the current loader - New CW-700S Upgrade Loader and unzip
2. Download the latest bin and unzip this file
3. Load the latest bin with the current loader as per these instructions:
Open the loader, select the latest bin in the "File" bar across the top.
For Options, select Download S/W.
To select a port, choose your COM port (usually 1). Then hit the start/load and wait for the receiver to display "-end". At this point, turn receiver OFF from the rear switch to reboot.You can now follow the last paragraph in the above USB instructions to help setup satellites and scan channels.
thanx goes to the author.
_____________________
Username: Lebrimal
Post Number: 113
Viewsat is going down, CW is you best bet
Username: Bugster999
Katy, Tx
Post Number: 87
does any one use it with a motor dish and how easy is that to do?
