Nfusion
Username: Craneop37
is everyones nfusion still up and running
Username: Ncx
Post Number: 63
Yup, wide open on both providers :-)
Username: Craneop37
mine went out a few minutes ago i have net cable hooked to it what do i need to do for some kinda update
Username: Ncx
Post Number: 64
You shouldn't need to do anything as long as your nfusion is connected to your router and the red light on the nfusion front panel is on. If the red light is off, try powering off the with your remote and then powering back on. If that fails check all your cables and make sure your nfusion has a connection to the internet.
Rule of thumb is, if your red light is off and IKS is up (which it is) you have no connection to to the internet through nfusion. Meaning something on your end is not setup right or not working right.
Username: Silver1123
Mexico, DF Mexico
Post Number: 437
My nFusion is working flawlessly. Didnt even blink today.
As Dean says, check that your cables are correct, that the Internet connection is on, that the settings on Nfusion are Dinamic for Internet DHCP, emmulation OFF
Username: Craneop37
got it now think my problem was emu was on
it just wanted to go out about every 4 minutes
Username: Runnerguy
Pluto
Post Number: 1033
WinchesterUpload
Username: Craneop37
Post Number: 7
something else that is not working too good is the pvr it freezes nfusion too
Username: Ncx
Post Number: 65
hey zulu, why you postin pics of yourself again?
