Which is best..what would YOU get?
Username: Blainew
Post Number: 2780
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16889
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18046
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13010
IM THE REAL SLIM SHADY
Post Number: 16675
clarion. i love clarion eq's.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5001
i had a clarion eq and i loved it!!! made my speakers come alive!
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 1094
I also vote clarion. I have that clarion one you posted. It improved the SQ on my components.
Username: Jakeyplaysbass
ASU
Post Number: 2299
Not that big of a fan for any of them...
The clarion looks to be the best on the list. Personally ive never messed around with it.
Username: Van_man
Boston South, MA
Post Number: 3251
This one looks cool.
http://cgi.ebay.com/NEW-CADENCE-6-BAND-PREAMP-PARAMETIC-MOTORIZED-EQUALIZER_W0QQ itemZ280188366472QQihZ018QQcategoryZ79841QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Blainew
Post Number: 2781
just ordered the clarion
Post Number: 5014
good choice blaine
Username: Nd4spd18
Northwest PA
Post Number: 5242
I would never use an in dash EQ at all...... an EQ is meant to be set to create a flat frequency response, and shouldn't be changed after that.
Some high quality trunk mount EQs even come with a plate that attaches to it to cover all the settings, to make sure they are not changed.
Username: Blainew
Post Number: 2782
and where would i get one
Username: Nd4spd18
Northwest PA
Post Number: 5257
Audiocontrol makes some very nice ones. There are a few others out there cheaper though.
