129W is moving South Indian channels? I need help to instal 118.7 &119 HOW MUCH?
Username: Fortec16
Post Number: 158
Need help to install 118.7 or 119?
How much to install?
How much is the LNB?
Need Help...email me.
Gus
Username: Fortec16
Post Number: 159
Anyone wanna help me?
Gus
Username: Vittu
Post Number: 106
you mean 121?? in order to receive 118/119 you need a circular lnb ~$30
Username: Adamof99
does anybody knows what should be the Antenna setting to get 119W and 118.7
I have Captive works 600s p.
and LNB type:
* Polarization: Circular
* Input Frequency: 11.70 - 12.75 GHz
* LO Frequency: 10.75 GHz
* Noise: 0.5 dB
Username: Post_man
Post Number: 28
For 119= 11,250
118.7= 10,750
Username: Kirankumar
Kenya
Post Number: 786
gus,
i am pastimg a post which was put up by Nalin,hope this will help you,
121s are moving to 118.7 Anik.
61.5 and 148 may also be reduced "in the near future"... "to make room for HD", but I have no confirmation on this.
119 and 118.7 can be had together on one universal LNB with a 30-33" dish.
The same Dish can also support 110 on a bracket.
Username: Nydas
Post Number: 6923
adamof99: The following information might be of some help. Please post back your experience in setting up for the benefit of everybody.
"If your LNB has separate outputs for 119 and 118.7, then in the Antenna menu
For 119, use LNB frequency 11250
For 118.7, use LNB frequency 10750
and use two ports of a switch."
"DUAL DSS LNB CB2008 for 118.7 119 Anik F3 FTA CIRCULAR. It works with all FTA receivers; just set LNB type as Universal LNB"
"ROC Model: CSS118
It's a Brand New Ku Band Circular Single Output LNB.
It's designed especially for catching 119 & 118.7 (Anik F3) at the same time using one such LNB. Each Output gives signal from both satellites.
Make sure you set LNB frequency as 10750, instead of regular 11250 in the receiver menu."
Username: Locnoir
Post Number: 32
Hi Nalin, for the converted Pansat 2700 with DN Superdish 500 and dual LNB. What would be the set up for 118.7 (Anik F3)?
Transponder=
LNB Freq=
LNB type=
22khz=
Legacy SW=
I curently have port1 for 119, and port2 for 110. Thanks!
Username: Locnoir
Post Number: 34
also, what if the Anik F3 sat is not shown in the box menu?
Username: Nydas
Post Number: 6933
Loc Noir : The best I can advise, I have already posted a few posts above and elsewhere where you have posted too.
Username: Locnoir
Post Number: 36
Thanks, Nalin! I just posted another question at that thread. Please advise.
