Pans@t 2700a Turns off by itself
Username: Dvsp0s3r
Post Number: 25
when i put in my binfile my box turns on but then when its finished it automatically turns off then it says b-7-5 and turns off buy its self again can aany1 help me, can u also give me the factory pinfile plz and thz
Username: Kirankumar
Kenya
Post Number: 751
seems like all helpers here ae taking a break.i suggest you go to [link removed] amd post you will get help.you will have to register but it is free for now.good luck
Kenya
Post Number: 756
if you stay here there is a jerk who is smart he will help you this is the guy
iamdrumming
Username: Iamdrumming
Post Number: 71
Username: Jebeni61
Post Number: 8
Hell i would try to ignore African dumb as$ spammer first Then I would try to load all over again,, factory bin boot b-75 etc,
Username: Rtap
FL
Post Number: 1573
load the factory bin first then load the current bin.good luck
Username: Dvsp0s3r
Post Number: 27
RTAP need the factory bin were can i get 1 plz and thz
Username: Saqeeb9000
Post Number: 1455
[link removed]
[link removed]
[link removed]
Username: Rtap
FL
Post Number: 1611
factory bin.
http://ftabins.net/showthread.php?t=3556
Username: Dvsp0s3r
Post Number: 28
RTp need another website this dosent let me open it.........................................
Username: Dimwitt
Post Number: 355
www.pansatusa.com/download.htm
2700A(b-75)
Username: Dvsp0s3r
Post Number: 30
its sayed i need a binfile be4 dec 17 2006, andy1 willin enough to give it to me plz&thx
