Sub out on 702 onkya
Username: Bbford
Post Number: 8
I have onkya 702 and all was fine until i moved my amp now i cant get any sound out of the sub i have tried differant sub cables that didnt work and when i try to wire the speaker and sub my amp shuts down at 50 on the volume scale witch is not that hi and yes i tried a differant sub that works and thats not it any one have any ideas other than back for repair?
Username: Jan_b_vigne
Dallas, TX
Post Number: 12017
Not much to go on. Are you certain the original sub is working properly when it's not connected to the receiver? Have you done any diagnostics on it?
Username: Bbford
Post Number: 9
no not yet i just moved and any thing i have to test with has not moved with me every thing was working fine unhooked moved it hooked it up 4 hours later nothing the sub does power up when you turn the amp on so there is somthing happening did try my budys sub witch works but still nothing sat on hold with onkya for 1 hour but had to hang up i guess i will try again tommorow and yes the origanal sub is working
