Bronze Member Username: Jonny_bKellogg, Idaho U.S. Post Number: 17 Registered: Oct-07 | i hooked up my wire harness to my HU, connected the ground, plugged in the radio wire, plugged in the harnesses and im not getting any sound. the unit powers up and is functional just no sound. i know that i wired it correctly becuase it is just matching the colored wires. what could my problem be? i do hear a slight crackle in my speakers every now and again but thats it . |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5245 Registered: Jul-06 | Are you sure it's wired correctly? The color of the wires on the HUs wiring harness does NOT always match the ones on the car. You can't just match the colors, you have to read the manual for the HU and for the wiring harness, and match the wires by function. |
Bronze Member Username: Jonny_bKellogg, Idaho U.S. Post Number: 18 Registered: Oct-07 | that was the first thing i did. i checcked all my wiring and its all correct. |
Bronze Member Username: Alpine97Greenwood, Indiana USA Post Number: 43 Registered: Jan-08 | Is this for you 90' mazda protege? If so let me know. I think you need to pull out the HU and double check your wiring. Crackleing noise is not good obviously. There is definatly a negative somewhere. You need to utilize another site to assure that the wiring code is correct. 1990-92 Mazda Protege Stereo Wiring Constant 12V+ Blue/Red Switched 12V+ Blue/White Ground n/a Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 4" Dash Left Front (+) Blue Left Front (-) Blue/White Right Front (+) Blue/Red Right Front (-) Blue/Yellow Rear Speakers 5 1/4" Rear Deck Left Rear (+) Blue/Red Left Rear (-) Blue/Green Right Rear (+) Blue/White Right Rear (-) Blue/Green |
Bronze Member Username: Alpine97Greenwood, Indiana USA Post Number: 44 Registered: Jan-08 | Oh yeah, to assure yourself of that wiring diagram go to www.the12volt.com. layter |
Silver Member Username: SqcheapGrand rapids, Michigan Usa Post Number: 122 Registered: Jul-07 | I always use a 9v battery, just touch the speaker wires and that speaker will pop. Does not tell you pos/neg unless you can see the cone move but at least it is wired to that speaker. |
Bronze Member Username: Jonny_bKellogg, Idaho U.S. Post Number: 19 Registered: Oct-07 | Im using a wiring harness so i dont need to know what every wire color is, not to mention i already know those by heart. im just gonna say screw it and get a new H.U. any one got one for sale/ give away? |
Silver Member Username: SqcheapGrand rapids, Michigan Usa Post Number: 125 Registered: Jul-07 | You mean you got a bought harness that plugs into the car with labeled wires to hook to the HU? I would still test the speakers with a battery. See if the HU smells funny. Make sure it is not a setting on the HU, or bad ground or something before you take out. |
Bronze Member Username: Jonny_bKellogg, Idaho U.S. Post Number: 21 Registered: Oct-07 | Yes i did buy a harness that plugs from the car into the HU. surprisingly enough it does smell funny and it gets really really, like burnt the piss out of my hand hot on the left side. i put my old stocker back in and the speakers work fine. |
Silver Member Username: SqcheapGrand rapids, Michigan Usa Post Number: 126 Registered: Jul-07 | Thats not good, power wire might be the one to get hot but man. Some of the high power HU say run a wire to battery, I never have but different cars use different size wire to HU. Well I never use HU amp either. |
