Port tuning question
Username: Durski
Post Number: 165
I went to a local shop today and they had 1 box for a 15" with a port on the side. I asked what it was tuned to and the guy said he thought it was around 48Hz????? Isn't that a little high?
Then I asked what it would cost ($200, I'll be building my own) for them to make me a similar box tuned to 32Hz and he said it depends on the sub, is this true? the way I understood it was tuning depends on the box alone. Not too sure if I trust this shop, every sub they had was single voice coil and memphis was their top of the line brand...
Username: Turnmat
Racine, Wi
Post Number: 571
48 hz tuning is pretty high unless you are going for competitions.
Memphis is some good quality Sh!t
Username: Teamrevolution
ATLANTA, GA USA
Post Number: 209
Diffrent subs can take up more or less room in the box changing the tuning.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1283
most car audio shop ppl.are just in it for the money.i only know one guy that runs a car audio shop,that can build boxes,and tell u every single thang u need to know about a system around my town
Username: Rovin
4 10 Pioneer...
Post Number: 12705
playing music with a 48hz tuning will sound like sh1t ....between 30-40hz is the norm but closer to 30hz u get alot more quality ....
Username: Davidt487
Texas
Post Number: 69
i was looking at memphis pr 15's and they are rec tuned at 40 hz
