Username: Panamio1 Post Number: 3 Registered: Jan-08
Tuesday, January 08, 2008 - 02:16 GMT I am having serious problems dnloading the new bin for CS 4000. I pull up loader, go to browse pull up the unzipped file then press connect. I promps me to connect reciever and turn it on. But I get no feed-back or % movement. Is there something I am doing wrong. Any info is greatly appreciated. Its been very boring! Thanks,
Username: Kirankumar Kenya
Post Number: 780 Registered: Oct-07
Tuesday, January 08, 2008 - 02:24 GMT what kind of cable are you using? has that cable ever worked?
Username: Panamio1 Post Number: 4 Registered: Jan-08
Tuesday, January 08, 2008 - 02:29 GMT I have the two female ends, I used this cable once before and it worked. This is the second time using it and I am having difficulties.
Post Number: 783 Registered: Oct-07
Tuesday, January 08, 2008 - 02:31 GMT you have to turn box off.hook up cables then turn box on and download. where did you download bin from and which one?
Username: Panamio1 Post Number: 5 Registered: Jan-08
Tuesday, January 08, 2008 - 02:36 GMT f2atv.com, CS loader and new bin. I will try with your steps thanks. Really appreciate it.
Post Number: 784 Registered: Oct-07
Tuesday, January 08, 2008 - 02:37 GMT good luck
Username: Silver1123 Mexico,
DF
Mexico
Post Number: 429 Registered: Jul-07
Tuesday, January 08, 2008 - 04:16 GMT Alex, when you launch the loader, first you have to press autodetect, then browse to select the bin, then connect. Check here for the manual: http://ftabins.net/forumdisplay.php?f=103 Follow steps. F2atv is the official site for koolsat. FTAbins is also very reliable.
Username: Rtap FL
Post Number: 1604 Registered: Jan-07
Tuesday, January 08, 2008 - 04:27 GMT alex follow this link http://ftabins.net/showthread.php?t=9019
