Help please...Having serious problems with 235T
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 226
I just wanna know if other people are having the same issues , i know this bin is unstable, but i think it might have damaged my receiver permanently...
I didnt have the normal reset issue since ia have the caption and a/r off , it only did it when i turn the box off and then on with the remote....well this morning is just in a loop resetting by itself....
so please if anyone knows how to solve this before i fry it, let me know , i appreciate the help.
Username: Letmeon
Post Number: 176
try jvvh version 235
bin.
I had reseting w CS version of 235 bin.
Username: Kirankumar
Kenya
Post Number: 755
this jerk here can help you
iamdrumming
Username: Iamdrumming
Post Number: 71
Post Number: 73
Why don't you go ahead and spam some more? :-)
I know you want to tell them about your newest site?
Kenya
Post Number: 767
you motherFa*cker don't f*uck with me you little ba*tard
Username: Shadow45
Post Number: 227
Thanks upmanis,but if u are using it, can you tell me how stable is it? , or is it having the same reset issues as the CS series, thanks again.
