VS Extreme setup...
Username: Sluggp
Post Number: 14
Can you use VS Extreme with a super dish with a HD LNB or do i need to get a dish 500 with dish pro lnb? I currently have it with the HD LNB but only get some channels. Is there a setting to fix this or are they not compatable?
Username: Madflea168
Post Number: 10
mine has super dish with hdtv covered the lnb, so I believed I do have the hd lnb on 110 and 119, both work good believed to be about couple hundred channels.
Username: Sluggp
Post Number: 16
what are your settings? I have it set up like it was dish 500. Are you using a dp34 box or running straight to reciever?
