Need suggestions on Mid For 120$ or Lower
Username: Torn
Post Number: 464
First off are powerbass product any good? And Secondly What would be the Best 6x9 Mids i can get For 120$ or lower? They will be Powered by a zapco AG350 amp.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5114
best 6x9 would be pioneer REVS, they're yellow if you can't find them by REV.
powerbass amps are good.
Username: Torn
Post Number: 466
PoweBass 6x9 not so good? any more options out there? thanks
Username: Torn
Post Number: 467
Also looked at those speakers, there are many of those "yellows" around, what particular model of it will be good? And the amp would power them well? Still more suggestions welcome thanks.
Username: Van_man
Boston South, MA
Post Number: 3249
Check out Polk DB line. I had them running off a Zapco AG 200 and they sounded good. MMats makes a nice set too. I think Chad Lee had a set for sale cheap. I would shy away from Powerbass speakers. The amps and subs may be ok, but I had 4 pairs of comps blow on low wattage. Maybe just me. Boston Makes a 6x9 sub.
And why 6x9? are you using them for mids? You would be better off with 6.5 mids.
Username: Torn
Post Number: 468
Hmm... I looked on the post but Berny Was happy about it, he already baught it i bet. Currently i have some wal mart 6x9 posted up in the back tied down by zip ties, and they start crapping out of me when i turn it up, the bass and all sounds like it's smacking itself. or yea i could do 6.5's i think, I think i need an adaptor also. Going into a 92 camry but can't find any adaptors for it.
I guess which 6x9 or 6.5's would be sugessted wich produces good bass also for 120$ or less.
