does anybody knows what should be the Antenna setting to get 119W and 118.7 I have Captive works 600s p. and LNB type: * Polarization: Circular * Input Frequency: 11.70 - 12.75 GHz * LO Frequency: 10.75 GHz * Noise: 0.5 dB
gus, i am pastimg a post which was put up by Nalin,hope this will help you,
121s are moving to 118.7 Anik. 61.5 and 148 may also be reduced "in the near future"... "to make room for HD", but I have no confirmation on this. 119 and 118.7 can be had together on one universal LNB with a 30-33" dish. The same Dish can also support 110 on a bracket.
adamof99: The following information might be of some help. Please post back your experience in setting up for the benefit of everybody.
"If your LNB has separate outputs for 119 and 118.7, then in the Antenna menu For 119, use LNB frequency 11250 For 118.7, use LNB frequency 10750 and use two ports of a switch." *****-------*****-------*****-------*****-------*****-------*****-------***** "DUAL DSS LNB CB2008 for 118.7 119 Anik F3 FTA CIRCULAR. It works with all FTA receivers; just set LNB type as Universal LNB" *****-------*****-------*****-------*****-------*****-------*****-------***** "ROC Model: CSS118 It's a Brand New Ku Band Circular Single Output LNB. It's designed especially for catching 119 & 118.7 (Anik F3) at the same time using one such LNB. Each Output gives signal from both satellites. Make sure you set LNB frequency as 10750, instead of regular 11250 in the receiver menu."
Hi Nalin, for the converted Pansat 2700 with DN Superdish 500 and dual LNB. What would be the set up for 118.7 (Anik F3)? Transponder= LNB Freq= LNB type= 22khz= Legacy SW= I curently have port1 for 119, and port2 for 110. Thanks!
