Cant get signal for 119
Username: Jathol
Post Number: 8
i have two recievers and two setalites 148 and 119. i am able to get channels from both setalites on one reciever but on the second reciever sonicview 4000 i am unable to get 119 signals. it seems to me there is issue with lagcy switch etc. need help.
Username: Adamof99
does anybody knows what should be the Antenna setting to get 119W and 118.7
I have Captive works 600s p.
and LNB type:
* Polarization: Circular
* Input Frequency: 11.70 - 12.75 GHz
* LO Frequency: 10.75 GHz
* Noise: 0.5 dB
* Dual output Upload
Username: Post_man
Post Number: 29
119=11,250
118.7=10,750
Username: Kirankumar
Kenya
Post Number: 785
quasim,
see ms like you might have asettings problem,
if you could post settings.lnb type and switch type and connection to switch we can help
