Just another rookie looking for help
Username: Bigmterry
Springtown, Texas
I must, as others I have read here, give a plethora of apologies for my ignorance in this field. I have a couple of older gentleman that I work with that have a couple of fta units 1.Extreme Viewsat VS2000 W/Remote but no cable and 2.CNX-MINI W/USB 2.0 and Remote. I offered to try to find out how to get them going so that I could make sure it was something I wanted to get into. They like so many others have become very discouraged w/all the technical situations, that they have had these in there closets not even trying to put them to use, I would really like to help these 2 older gentleman out. Is there anywhere I can get any information as to downloading what I need to use a dish 500 sat dish that is already working on my dishnetwork Rec.? Thanks again for any help regarding this!!
Username: Jurj1
Post Number: 419
Try here: [link removed]
Username: Vyizder_zomenimor
Post Number: 33
Viewsat discontinued the Xtreme- you need a null modem cable to program it. They still support it and lots of dealers still have them in stock, cheap.
Username: Bigmterry
Springtown, Texas
Thank you Orziz Aziz I appreciate your time.
Username: Bigmterry
Springtown, Texas
Sorry I also appreciate your help Tony Soprano
