Silver Member Username: 94_toyPost Number: 129 Registered: Sep-07 | I need a 12" sub, looking for SPL that can be found on ebay for under $199. I have a kicker KX400.1 to power it. THX YALL |
Silver Member Username: Surferdude9371Admiting your an a$$ho... Post Number: 410 Registered: Mar-07 | what ohm loads is that stable at?? can it be online not just ebay? |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7404 Registered: Feb-06 | phoenix gold rsd |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5694 Registered: Jan-06 | assassin |
Gold Member Username: MgbcsLincoln, Nebraska Post Number: 1982 Registered: Dec-06 | For SPL, why not look at an L5. If SPL is TRULY all you're looking for, consider that. If you want some decent sound, look towards Rob and Mat's suggestions. First time ever suggesting an L5 |
Silver Member Username: 94_toyPost Number: 131 Registered: Sep-07 | i was thinking a D6 or a RE SE, arent the RSD really cheaps subs thoguh>? |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5700 Registered: Jan-06 | rsd are cheap but good. plus your budget is only 199 so that is cheap. |
Gold Member Username: camBC Canada Post Number: 1549 Registered: Nov-06 | Too bad the MAWs are D4. |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 696 Registered: May-07 | What about a 12" BM? |
Gold Member Username: 420alldaylongPost Number: 3139 Registered: Sep-06 | Kicker KX400.1 is 2ohm stable.^^^^^ Mach5 Audio MAW-12" AudioQue SD2.5 12" |
Gold Member Username: camBC Canada Post Number: 1552 Registered: Nov-06 | Ah, good to know. I figured KX = 1 ohm stable. In that case, I love my MAW-12. It's awesome. Be sure to port it. http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=205 |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 697 Registered: May-07 | Hows the sq and output on a maw? They are only $96 on ssa.com. I've heard they will eat you alive on the lows, and was curious to learn more about them. |
