Silver Member Username: Motomattic3Post Number: 574 Registered: Oct-06 | hello I'm looking to build a sub box that is water,sand,mud proof. Its for a low depth pioneer 10 sub. which will be mounted in a dune buggy. hints why i need a weather proof one. i could make it out of mdf and have it line-x so that its water proof but does anybody got any ideas on how to build one? |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 12233 Registered: Jun-06 | A system on a dune buggy????? |
Gold Member Username: JtownTeam Revolution, Texas Post Number: 1578 Registered: Mar-07 | build a box and bedliner the b1tch...don't know what to do about covering the subs really though |
Silver Member Username: Motomattic3Post Number: 579 Registered: Oct-06 | thats what i though lol. the new sand rails have sounds systems in them but they cost like $50k plus (the sand rail that is) but I haven't seen one with sub in it before. my dad owns a buggy frame and i have a kl v6 probe motor in my yard which i plan on supercharging but to get back to topic does anyone have any ideas on a weather proof box? if you want to read more about my project its here http://forums.probetalk.com/showthread.php?p=1923251054&posted=1#post1923251054 I have to save up a bit of money and thats what im trying to figure out now, the aprox cost of my project and heres my dads long/mid travel suspension vw buggy http://i143.photobucket.com/albums/r158/destroyerzx1/previewalldunebuggy.jpg |
Silver Member Username: Motomattic3Post Number: 580 Registered: Oct-06 | my reply above is to Paul Larrea |
Silver Member Username: Motomattic3Post Number: 581 Registered: Oct-06 | hmm i don't know much about box design but what about a box and a extra area infront of it to give it room to breathe but also completly enclose it and then line-x it which is the same thing as bedliner. of course you would never beable to acess the sub unless you broke the box or put a seal on it and made hinges and such but. kind of like this |
Silver Member Username: Motomattic3Post Number: 582 Registered: Oct-06 | it only requirs a .7 cubic feet box so would i make it 1.4 cubic feet with a panel in the middle? |
Gold Member Username: Bnd_rulezPhoenix, AZ USA Post Number: 1051 Registered: Mar-05 | Bandpass style maybe? Make it like you have above but instead of a big enclosed box, throw some plexi on the front and screw it in good. I don't know if it'll work bit it's just an idea. |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 2... Post Number: 5788 Registered: Mar-04 | Just get a marine ready sub and solder/heat shrink all connections. Where to mount the amp my also be a problem for you. |
Silver Member Username: DurskiPost Number: 161 Registered: Nov-06 | bandpass would be the only option that I can see working... for a short time, Good luck keeping moisture away from the amp and HU... isn't a dune buggy too loud to hear radio anyway? |
Silver Member Username: MendonmafiaUSA Post Number: 477 Registered: Aug-06 | just make the sub fire downwards that should protect it quite a bit |
Gold Member Username: Denali_on_22sYou can call me Scroog... Post Number: 3466 Registered: Feb-06 | well that wont completely protect is mendon... you could build an isometric box... |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16584 Registered: Oct-05 | i don't think you should put a sub. it won't sound good. bass needs to resonate off of something and you got nothing. the subs would be out in the open. |
Silver Member Username: Motomattic3Post Number: 583 Registered: Oct-06 | hmm, true |
Gold Member Username: Tatonka-[Team Audib... Post Number: 1281 Registered: Mar-07 | Just get you some decent marine components :D A sub would be kind of pointless like Chad said. |
