Viewsat ultra locked
Username: Cebbie
Post Number: 8
My ultra is frozen and locked up- it does not respond to any buttons and turning the unit off in the back does not change anything - it shows the same channel as if it was autorolling but does not show any movement on the sat signal --any idea's
Username: Ghostcdn
Pescara, Abruzzo Italia
Post Number: 31
reload the factory bin
Username: Cebbie
Post Number: 9
I assume this has to be done with a computer - Which loader would you use and where can I find this file - Thanks for your help
Username: Aright
Post Number: 11
Your kidding. right?????
Username: Smoke74
Post Number: 100
you better call whoever installed your dish and ask for your money back
Username: Madflea168
Post Number: 9
go read this thread and follow "the FTA tester" directions.
https://www.ecoustics.com/electronics/forum/home-video/428318.html
Username: Ke5aqn
Post Number: 3261
Username: Directmc
Post Number: 8
Plug your unit out, then in again.
