Help fast !!!! wiring 4 ohm amp with subs need help?asap
Username: Mike_16
Reedsburg, Wisconsin Us
Post Number: 802
ok the tarantula amp is rated 1600 @ 4 ohms at 1 channel. then 800 @ 2 ohms at 2 channel. ok so we looked here http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=4
and it is wired like that sthe subs except eatch one has both pos and neg wires and plugged into the amp. wel u cant just bridge them together and have posotive and negative from eah sub they dont even play or make sound when u do that so how is it rated 1600 @ 1 channel?
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 1365
Only run a single run of wire for each pos and neg just like in the picture.
Other than that I am at a loss as to what you need.
Username: Mike_16
Post Number: 805
but u cant bridge that amp. so just use 1 channel an du wil stil get 1600? i thought maybe 800
