Username: Guanajuatos_best Post Number: 138 Registered: Jul-07
Monday, January 07, 2008 - 02:29 GMT i would like to know if loading a sat file to vsxtreme help on getting more transponders and frequencies? if not, how can i get more tp's?
Username: Kirankumar Kenya
Post Number: 742 Registered: Oct-07
Monday, January 07, 2008 - 02:33 GMT are you missing any channels right now?
Username: Guanajuatos_best Post Number: 140 Registered: Jul-07
Monday, January 07, 2008 - 02:44 GMT yup. many channels.
Post Number: 743 Registered: Oct-07
Monday, January 07, 2008 - 02:47 GMT ok, have you checked your settings? give me more info, how many satellites,what birds what kind of switch if you have one.also if you can give me settings
Username: Guanajuatos_best Post Number: 142 Registered: Jul-07
Monday, January 07, 2008 - 02:51 GMT one antenna. dish 500. the one with 2 lnb's. signal=the strongest i can get(west coast) settings: FOR 119 LNB POWER= OFF LNB TYPE UNIVERSAL LNB HIGH=11250 LNB LOW=11250 TP. FREQ.= 1224 DISEQC 1.0= PORT1 (PORT2 FOR 110) MOTOR=OFF LEGACY SW=NONE all settings are the same for both satellites. only the port for diseq change.
Post Number: 744 Registered: Oct-07
Monday, January 07, 2008 - 03:00 GMT this is what you should have for 119 lnb power ON lnb type SINGLE lnb freq 11250 tp freq 12457 diseqc 1 off off for 110 lnb power ON lnb type SINGLE lnb freq 11250 tp freq 12224 diseqc 2 off off once you have these setings right then you can go ahead and scan
Username: Guanajuatos_best Post Number: 146 Registered: Jul-07
Monday, January 07, 2008 - 03:03 GMT OK. will try. thank you
Post Number: 746 Registered: Oct-07
Monday, January 07, 2008 - 03:04 GMT if this does not work post again and i will help.good luck
Username: Runnerguy Pluto
Post Number: 1026 Registered: Sep-06
Monday, January 07, 2008 - 03:12 GMT In the Remote Control press MENU: 1] Installation>>press Ok 2] Channel scan press OK then go to Edit tp press OK 3] Then highlight the tp you want to SCAN. 4] Press OK or START SEARCHING. 5] EXIT>>>SAVE.
Username: Guanajuatos_best Post Number: 147 Registered: Jul-07
Monday, January 07, 2008 - 03:23 GMT ok. ok.ok.ok just scanned both satellites. and got a total of 221 tv channels and 70 of radio. also each channel appeared doulbe.
Post Number: 749 Registered: Oct-07
Monday, January 07, 2008 - 03:27 GMT did you change the settings as i had posted?
Username: Guanajuatos_best Post Number: 148 Registered: Jul-07
Monday, January 07, 2008 - 03:29 GMT yes, but you said that lnb type had to be SINGLE, but there is no single in my vs. there is : STANDAR, OCS-DP, LEGACY TWIN LNB1, LEGACY TWIN LNB2. LEGACY QUAD LNB1, LEGACY QUAD LNB2 AND UNIVERSAL.
Username: Guanajuatos_best Post Number: 149 Registered: Jul-07
Monday, January 07, 2008 - 03:30 GMT I also scanned them both at the same time. together.
Post Number: 750 Registered: Oct-07
Monday, January 07, 2008 - 03:34 GMT ok good, stay with me, i want you to try OCS-DP for both ,we will get it right.do this and rescan. the reason i am doing this is right now it is dark to go on the roof to see lnb type,but with dish 500 the one i am suggesting,should work.if that dont work we will keep all the settings as i said but change lnb to standard and scan.get back after scan
Username: Guanajuatos_best Post Number: 150 Registered: Jul-07
Monday, January 07, 2008 - 03:35 GMT let me try.
Username: Guanajuatos_best Post Number: 151 Registered: Jul-07
Monday, January 07, 2008 - 03:45 GMT yup my man. it worked. thank you very much. you rock.
Post Number: 752 Registered: Oct-07
Monday, January 07, 2008 - 03:49 GMT the only paisa left, this was my last help on this site, i am glad i could help.but as you know there is just too much bashing going on here,if you are ever stuck post for me on crazy.com and we will help.happy viewing for now
Post Number: 753 Registered: Oct-07
Monday, January 07, 2008 - 03:51 GMT also write those settings down and keep them safe for future use.good luck
Username: Guanajuatos_best Post Number: 152 Registered: Jul-07
Monday, January 07, 2008 - 04:06 GMT all right will look for you. true about bashing.
Post Number: 758 Registered: Oct-07
Monday, January 07, 2008 - 04:19 GMT good luck buddy
Username: Jebeni61 Post Number: 5 Registered: Jan-08
Monday, January 07, 2008 - 11:39 GMT You can stay here.. there is a lot of good people here who will help you THE ONLY.... African spammer you are not only one here who helps..so please get lost to your site spammer
