New member Username: CebbiePost Number: 8 Registered: Sep-07 | My ultra is frozen and locked up- it does not respond to any buttons and turning the unit off in the back does not change anything - it shows the same channel as if it was autorolling but does not show any movement on the sat signal --any idea's |
Bronze Member Username: GhostcdnPescara, Abruzzo Italia Post Number: 31 Registered: Dec-07 | reload the factory bin |
New member Username: CebbiePost Number: 9 Registered: Sep-07 | I assume this has to be done with a computer - Which loader would you use and where can I find this file - Thanks for your help |
Bronze Member Username: ArightPost Number: 11 Registered: Dec-07 | Your kidding. right????? |
Bronze Member Username: Smoke74Post Number: 100 Registered: Oct-07 | you better call whoever installed your dish and ask for your money back |
New member Username: Madflea168Post Number: 9 Registered: Jan-08 | go read this thread and follow "the FTA tester" directions. https://www.ecoustics.com/electronics/forum/home-video/428318.html |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3261 Registered: Sep-06 | |
New member Username: DirectmcPost Number: 8 Registered: Dec-07 | Plug your unit out, then in again. |
