AFTER UPLOADING NEW BOOT FILE AND BIN WHEN ENTERING parental control i am no longer able to enter the keys manually the only thing i get is the old pin and the new pin info it no longer sends me to where you enter your new keys can anyone help me or tell me what i havbe to modify thank you
or to skip that step just press 8282 on your remote like you would normally change you channel and it will take you in parental control menu, then go to nagravision2 to enter keys manually
