Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 539 Registered: Feb-07 | there's so mainy things to do on this amp dose some one got this amp and help me this thing even tells me what the time is lol i got a 18"Q on it box is 9 @ 32Hz thanks guys |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16645 Registered: Oct-05 | all i can say is read the manual and study it good. its got so much options its not even funny. lol. i used to have the sx900.2. but if you have specific question, i can attempt to help you out. i can't explain the whole thing cause there would just be too much to type. lol |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 541 Registered: Feb-07 | haha thanks Chad were to start umm (LPF FREQUENCY&Slope), (HPF FREQUENCY&Slope), (EQ BASS/CUT,BANDWITH,FREQUENCY), (GAIN BANDWITH AKA whats coming from my H.U =Clarion VRX775VD), now the (GAIN) now i think thats its but u know what there is still alot more but i don't think i need it? ok now were is the SSF??? |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16647 Registered: Oct-05 | ok here we go. first of all, congrats on buying an awesome amp. LPF & slope......well you know what lpf is right. you set it a frequency you want your subs to play up to. example, if you set it to 80hz then it will play any frequencies below 80hz. the slope is how steep or wide you want to roll off. i usally set it at 12db. but if you want a steeper slope, 24db is good. HPF & slope.......this is your subsonic filter. you set it to a frequency you don't want your amp to play below. and i explained to you what slope is above. EQ BASS/CUT,BANDWITH,FREQUENCY......this is basically your bass boost and eq. i would just disable this. you can play around with it to see what you like. for me i like to make it as natural as possible. Gain bandwidth.......you should see voltages on the screen. if your headunit is 2v then you set that to 2v and so on. i like to set mine a little below my headunit's preout voltage. example, if my hu's preout is 4v, i like to set the gain bandwith to 2v. Gain.....you set that to match the voltage output of your head unit. its like the gain bandwidth is the gain also and the gain setting would be to fine tune the gain after that. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 543 Registered: Feb-07 | ok on setting the gain i did this http://www.subwoofertools.com/forum/setgain.asp the box the amp came with said it was doing 1430 rms and that is 37.8v and 1250 is 35.4v i don't even get to 30v with the gain all the way up if i put in a lil bass boost i can get to it? |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16654 Registered: Oct-05 | the turn the gain bandwidth down. where is your gain bandwidth set at? no bass boost please. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 544 Registered: Feb-07 | ok no BB! umm i think the lowst it will go i think 1v |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16660 Registered: Oct-05 | put it at 2v and try it. how far did you turn the gain up? also what cd are you using when setting the gain with dmm? make sure you hu volume is at 3/4. ahh but you know that since you put a link to the site. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 545 Registered: Feb-07 | val max is 33 i put it at 26 and i got a mp3 50Hz on my ipod from R,E there test tones |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16662 Registered: Oct-05 | what voltage is it reading? also why don't you set the gain down and connect the subs and take a listen. see if the subs get loud. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 546 Registered: Feb-07 | i don't have a volt mitter on me right now i will latter ok now HPF i was thinking 26Hz should do it? i'm at work right now. i'm going to go be going to lunch soon and buy one |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16664 Registered: Oct-05 | oh ok. lol. is your box ported? if so what is it tuned to? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 547 Registered: Feb-07 | yes 32Hz on my sweet 18"Q |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16666 Registered: Oct-05 | nice. 26hz seems cool. you can raise it up a bit though. like 28hz would be cool too. lol. set the slope of your hpf at 24db. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 548 Registered: Feb-07 | ok i got one i put it on ACV 200 the GAIN is 12db and the miter reads 14.3?? i but the BB flat the turnd it up a lil and the miter went up?? but wtf only 14.3 at 12db? |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16670 Registered: Oct-05 | what do you mean the gain is at 12db? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5232 Registered: Jul-06 | DON"T play the test tone from your ipod. That is probably the problem. Burn it on a CD. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 550 Registered: Feb-07 | hey chad can you call and help me set this amp i even had an ex kicker worker set and my us amps xt-2000d was hittin alot harder 1(402)610-3149 thanks man |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16700 Registered: Oct-05 | so how did it go quentin? |
Gold Member Username: JkidderGunshine , State Flawda Post Number: 3001 Registered: Nov-05 | he blew himself, his amp, his sub and his car up.... haha im eager to hear how it went also... |
Bronze Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 76 Registered: Dec-07 | me and q did some more tuning on the amp and got it sounding really good now but need to find out if you turn off the hpf slope dose mean that the subsonic filter is off |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 551 Registered: Feb-07 | thanks timmy! yea what he said ^^ and about the ssf too o and i'm getting 14.9v at idle w/o music and with i'm getting 12.1v when moving it like 13.3-14.3 i need BIGGER alt |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16702 Registered: Oct-05 | yea when the slope is off then its off. nice glad you got it the way you like it. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 552 Registered: Feb-07 | then i'm thinking i need it on i turnd it b/c it wasn't playing the lows?? with it off it dose? |
Bronze Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 79 Registered: Dec-07 | then do we need to turn it back. sent the sub is in a ported box. or will it be ok? |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16703 Registered: Oct-05 | then turn it on and put the slpe on 12db. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 554 Registered: Feb-07 | ok i think this may be my last kicker amp? sundown or us amps |
Bronze Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 80 Registered: Dec-07 | yeah same here, to smart for me |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16705 Registered: Oct-05 | yeah that amp is tricky. but if you get used to it and learn what every setting does, the sq is nice. what is also cool is if you get the wired remote. you can change all the settings from the front of you car. also did you save your settings? that way you can try out other settings and if you don't like it, you can always go back to the way you had it with a touch of a button. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 555 Registered: Feb-07 | i tryed to but i can't get it to save? |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16707 Registered: Oct-05 | you just push and hold the button down for a few seconds. |
Bronze Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 81 Registered: Dec-07 | we can figure out how to save settings, and he has the sxrc remote for the amp |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 557 Registered: Feb-07 | yea i will try it again i kno every setting lol i have set this thing so mainy times |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16708 Registered: Oct-05 | nice you have the remote. that thing is so awesome. if i ever get that amp, i know who to ask for help now. lol. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 558 Registered: Feb-07 | well when i get my dd i think i'm going to keep it with my Q i like the Q but i don't want to sell it. i may sell the sx1250.1? i kno what amp i'm getting 2 MD2D on the 3518's |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16710 Registered: Oct-05 | i was just sayin man. lol. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 561 Registered: Feb-07 | its cool. i was thinking about it! but now i think i got it working will see what happens? i thinking its hitting hareder with the sx. i wish i could use a TL to miter this. thanks Chad |
Platinum Member Username: BestmankindIM THE REAL SLIM SHADY Post Number: 16712 Registered: Oct-05 | np man. good luck with everything. you too timmy. |
Bronze Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 86 Registered: Dec-07 | yep thanks Chad lee |
